How to modify your stock "lancer" gauge to accept useful gauges
I might work on dimming it later, but I sort of like it being brighter because it is easier to see.
Just for anyone still wondering, as I was... You can take the innovate lc-1 wideband gauge and fit it in here pretty easily. You simply take the gauge, and clip the metal ring off:
Then take the lens off, and you are good to place it in there using the instructions above.
Comes out exactly like monochrome's picture above.
Thanks for making this great how-to!!
I just disassembled an LC-1 gauge but instead of actually clipping/cutting the metal ring as instructed above...you can just pry it from the back with a small flathead screwdriver. Makes it cleaner and also usable if you ever decide to use the housing from the gauge itself.
Just my 2 cents here. I'm going to do this install very soon and will post pictures from mine as well!
^^ looks great!
i wonder.. has anyone ever relocated the lights you remove while doing this?
and what about the lame temp gauge?? a matching after market one would surely look better.
found a really cool nitrous gauge I will put in mine http://cgi.ebay.com/ebaymotors/Elect...item4cf8e2b794
well i actually got around to doing this mod this weekend. i used the Innovate DB gauge (usually found with the LC-1)
i need to find a smoke lens of sort to bring down the intensity of the gauge. but other than that it wasnt bad at all. alot of trimming and cutting but its done and looks pretty good for now.
By vicmreyes at 2012-01-16
