fuel pump install
Old Oct 26, 2008 | 06:58 PM
wasabisnooter's Avatar
Originally Posted by hytek369
does bigger pump always equal to more gas consumption? or will engine just use as much as it needs?
can anybody answer this?
Old Nov 6, 2008 | 08:45 PM
HyaboostaIX's Avatar
If all you are doing is swapping pumps...the engine will just use as much as it needs. You won't see a difference in gas mileage without bigger injectors/cams/tune...etc.
Old Feb 15, 2009 | 01:49 PM
b00sted1's Avatar
don't forget to take the gas cap off first to let the pressure out of the tank first!
Old Apr 20, 2009 | 07:40 PM
crisdiarata's Avatar
Hello guys just want to know if anyone can tell me how to connect dual walbro 255 pump external and in-tank, I want to know both so I will do the easy one, what I hear is than dual external is better.
Old Jul 13, 2010 | 10:42 AM
ta ace's Avatar
what if i put the white thing inside the black grommet cause i thought thats where it was?
Old Nov 29, 2010 | 06:42 PM
rommel6.5tme's Avatar
What car was this you replaced the pump??
Old Jan 25, 2011 | 04:47 AM
Could you just take out the white plastic piece than show in the picture inside of the red circle? What it's for?
Old Feb 13, 2011 | 06:39 PM
Blackevoate's Avatar
Unhappy CPS Help....
OK so im not getting any spark. I have read as many posts on here as i can find about the CPS. I am looking for a how to on replacing the sensor. because based on what i found most said check the CPS (Crank position sensor), than the coil packs , and also the ecu.. so im starting with the cheaper one first. The car wont start so i cnat see any of the codes because it hasnt thrown any.. any help will be great....
Old Nov 23, 2012 | 03:06 PM
benihana242's Avatar
Does anyone know at what power level this becomes "essential?"
Old Sep 16, 2015 | 12:17 PM
James E-R's Avatar
useful advice, will be trying this myself when i pick up my evo 2 tomorrow!!
RSMike
138
Jul 20, 2025 09:19 AM
94AWDcoupe
182
Feb 17, 2025 10:42 PM
xXANCHORMONXx
Apr 5, 2024 01:01 PM
PAdutch
Oct 18, 2016 07:42 AM
jzralliart
13
Sep 13, 2016 05:55 PM
