Turbo Timer Install Help
Old Jan 26, 2007 | 09:32 AM
mitsumanny's Avatar
I Just Installed A Blitz Dc Iv T.t. Into My '06 Mr. I Admit I Got A Lil Excited So I Was Stupid And Only Tested If It Turned On/off And The Boost Gauge Feature Of The T.t. Before Putting Everything Back Together. Good News Features Worked, Bad News It Dont Turbo Time My Car. Im Hoping Thats Its Just The Vampire Clip To The E-brake That May Be Loose So That I Dont Have To Take The Steering Column Apart. Is My Assumption Correct, Could It Be So Simple? If Not, Any Ideas Are Welcome. Thanx In Advance.
Old Jan 26, 2007 | 09:34 AM
willsevo's Avatar
did you install it with a wiring harness?
mitsumanny's Avatar
O I Used The Wiring Harness In Case That Helps Find Any Possible Solutions.
Old Jan 26, 2007 | 09:37 AM
willsevo's Avatar
if you used a wiring harness and all connections are secure I would check the ebrake cut off wire. If that dont work you might have a defective product, the TT only has the harness conection and the ebrake conection.
Old Jan 26, 2007 | 09:41 AM
tweakdsm's Avatar
Correct, there is only 1 wire that goes to Ebrake. If you got the harness like you said, install is simple. gl
Old Jan 26, 2007 | 09:49 AM
tony_b's Avatar
Just ground the ebrake wire. That's all it takes besides the harness.
Old Jan 26, 2007 | 10:40 AM
mitsumanny's Avatar
Aight Thats Wha I Wanted Hear Thanx, Much Appreciated.
Old Jan 26, 2007 | 10:28 PM
mitsumanny's Avatar
I checked the ground wire when i got home and saw the problem, i didnt completely clip down the vampire clip So it works great. But now i gots anotha question, hopefully ya'll can help. car stays on, timer counts down, car turns off, but lights down auto shut off anymore. They do after i open the door though. Any ideas?
Old Jan 26, 2007 | 10:39 PM
tony_b's Avatar
You could try... shutting them off before taking the key out of the ignition?
Seriously, I don't know. I don't bother with a TT in the Evo. I had that same one in my 2G though...
Old Jan 26, 2007 | 10:44 PM
Dinothegreat's Avatar
How hard was it to install the boost guage part?
Old Jan 26, 2007 | 10:48 PM
tony_b's Avatar
Not hard at all. Just search on here for the place to tap the source and run the hose. Then you just plug it into the back of the TT.
Old Jan 27, 2007 | 03:15 AM
moreryce's Avatar
the lights turn off after 2 minutes.. incase anyone wants to know...
Old Jan 27, 2007 | 11:19 AM
mitsumanny's Avatar
The t.t. came with a vaccum line and a t. I just tapped into the vaccum line going into the stock boost gauge. After 2 min. u say moreryce. I reckon i'll double check that, Thanx.
AWD 8
18
Dec 21, 2011 10:12 PM
cs82685
May 14, 2007 03:05 PM
sexycinnomne2
12
Sep 21, 2006 07:46 AM
fatalbert69
Mar 27, 2005 11:31 AM
Ultor
Oct 11, 2003 09:18 PM
