DIY billet oil catch can for about $20
Old Jun 28, 2007 | 06:45 AM
mdsevo06's Avatar
Had anyone ordered this Can and it came incomplete? Mine arrived yesterday with the Can and only one fitting, the top straight one and two clamps....no angled fitting for the side and no valve at the bottom as shown in the picture. Tried calling them, but of course there one and only customer service rep. is on vacation until monday....little disappointed I went this route.
Old Jun 28, 2007 | 06:51 AM
hokiruu's Avatar
that is very disappointing and i'm sorry to hear that. mine came complete. pegasus is usually alot better than that.
Old Jun 28, 2007 | 07:33 AM
mdsevo06's Avatar
I'm sure this is a uncommon event and hopfully gets resolved next week. Thanks for responding Hokiruu, just wanted to make sure this was not normal.
EDIT: Pegasus did send out the missing fittings, with no question. A+ customer service.
Old Jul 6, 2007 | 06:42 PM
EVO-IX-MR's Avatar
Thanks for this DIY hokiruu!!
I built two for myself with a tube running to the bottom of each can.
Here are some pictures of my setup. I have not hooked up the PCV side yet as I need to buy some more hose.
My dirty engine bay.
I found this bracket in my box of junk and it worked perfectly for mounting the catch cans.
The MBC and catch cans match each other nicely...and that is what is important here.
Old Jul 7, 2007 | 05:47 PM
obri'sevo's Avatar
great write up, ill be doing this within the next few days for sure!
Old Jul 8, 2007 | 11:32 AM
Joehunk's Avatar
How often do you have to empty these things? And how do you empty them? It looks like the bottom end is hard to get to.
Old Jul 8, 2007 | 02:47 PM
EVO-IX-MR's Avatar
I just installed them, so I am not sure how often they will need to be emptied. The previous Breather side only catch can I had was completely empty after a year of use, but that could be due to a poor design. I imagine once I hook up the PCV side it will have something to empy out every couple oil changes.
When it comes time to empty them I will just unscrew the one #4 bolt holding the bracket, lift up the cans (left some slack in the hoses) and drain them into a pan or something.
Old Jul 9, 2007 | 07:29 AM
hokiruu's Avatar
It's great to see someone else trying this. Good setup idea Evo IX MR, I'd like to see the whole istallation complete.
They don't really need to be "emptied" very often at all. If you're driving the way most people do you could probably go a years and it still wouldn't over flow or anything. It's not large volumes of oil or anything, but rather fine and consistent oil vapor we're condensing and collecting, so it accumulates very slowly, but would otherwise make a mess in your intake tract.
mdsevo06 did your order get resolved?
Old Jul 9, 2007 | 09:31 AM
mdsevo06's Avatar
Yes it did, they shipped out the missing pieces right away and arrived in only a few day. Great customer service from Pegasus.
Thanks for asking.
Old Jul 9, 2007 | 09:39 AM
hokiruu's Avatar
glad to hear it. that sounds more like the pegasus i know.
Old Jul 9, 2007 | 10:10 AM
EVO-IX-MR's Avatar
Yeah I am sorry I didn't take pictues as I was putting the can together. I will next time as I will be making more.
The only frustrating thing about the Pegasus cans is some of the holes are not threaded real good so no matter what you cannot get the fittings to go in straight or all the way. So one of my cans is perfect and the other is not quite perfect because the bottom drain fitting is not straight or all the way in. It is secure and won't leak though.
Other than that they are pretty easy to put together and install.
Thanks again for the DIY!!!
Old Jul 9, 2007 | 10:26 AM
hokiruu's Avatar
that's weird about the fitting tolerances being so high, i didn't notice anything like that but i'm sorry you did. well as long as it works and looks somewhat decent i guess it's doing it's supposed to.
Old Jul 9, 2007 | 10:32 AM
mdsevo06's Avatar
I also noticed the same thing. I can get the straight fitting in about half way and the 90 elbow in only a few threads. Can always try re-tapping it a little, just to clean it up a little.
Old Jul 9, 2007 | 10:39 AM
hokiruu's Avatar
thinking back i think i may have had to crank on the fitting quite a bit to get them all the way in as well. i just attributed this to the teflon tape. i figure it's fine as long as it doesn't leak haha!
Old Jul 9, 2007 | 11:01 AM
EVO-IX-MR's Avatar
I am not unhappy with the Pegasus product at all.
It is really no big deal, I was able to get the fittings in far enough they don't look bad and they function as needed; which is really what is important.
