HOW TO: "gus mod" dejon tools leak stop kit (MR BOV!!!)
Old Mar 26, 2007, 05:38 PM
trinydex's Avatar
http://www.thedodgegarage.com/turbo_bov_mod.html original gus mod site
http://evo.dejonpowerhouse.com/ purchase leak stop kit from dejon tools
remember you can buy the 1g bov from them premodded for the leak stop or just gus mod.
We tested the 1g BOV (Air Bypass Valve) for leakage three ways: 1. Stock 2. Crushed 3. Crushed with Seal Kit Mods. The test fixture was a 7gal (.966 cu ft) air tank with a flange welded on the top. We mounted the BOV and filled the tank to 30psi, then used a stopwatch to time the leakage and recorded time vs psi as it leaked. Then we pressurized the tank with the modded valve to 50psi and IT HELD! Leakage was only .060 SCFM The data is below:
SCF is the Standard Cubic Feet of air in the tank at that pressure. eg at 30psi there are 2 cu ft of air that can escape in a 1cu ft tank.
SCFM is the leakage rate in SCF per minute. (60*SCFM change/Telapsed change).
Telapsed is elapsed time in seconds.
Results: in this test, from 25 to 24psi, the crushed BOV leaked .232SCFM the stock .251 (within experimental error) while the Modded BOV leaked only .046 or 1/5 ( 5 TIMES LESS).
http://forums.*******.com/showthread.php?t=2574 where mr bov pics were taken from.
this is more or less the gus mod for evo9 bov
Gary's Talon BOV Hi-boost Modification page
90-93 Talon Blow Off Valves are an excellent part for the money: They are cheap new ($86), EVEN cheaper used from a junkyard ($5-$20) and are very durable. They have only one weakness however and that's at boost levels over 17 psi the valve starts to leak pressure to atmosphere and you loose power!
I'm going to show you how to fix that!
Tools & parts you will need:
10-24 standard tap
6 mm tap and die
1/8 & 9/64 drill bit and drill
brake line cutting tool
short piece of 3/16 steel brake line
JB weld epoxy
10-24 x 3/16 set screw (I got mine from Home Depot)
Allen key for set-screw
Brake cleaner
WD-40
PLEASE READ ALL THE STEPS BEFORE DOING ANY WORK SO YOU HAVE A CLEAR UNDERSTANDING WHAT'S GOING ON AND WHY.
Step #1 is drilling an external boost reference port.
The idea here is to drill a hole using the 9/64 drill-bit on a slight angle so there is room in the base of the BOV for the 3/16 long set-screw we will be installing later. The idea is to intersect the port going from the flange to the lower part of the diaphragm. After you drill the hole its a good idea to use a vacuum cleaner to ensure there are no chips of metal in the diaphragm port.
For Step #2 you are going to tap the hole with the 6 mm tap. It's a good idea to do this with the port facing down so chips do not fall into the diaphragm and use the WD-40 to lube the tap to prevent it from galling the metal. After you done clean the area (and the tap) with the brake clean so no traces of oil remain.
Since we are taping holes, break out the 10-24 tap and run it in the port opening at the base of the flange.
ONE OR TWO TURNS IS ALL YOU NEED!!! I didn't even bother to lube the tap for this step, the 10-24 x 3/16 set-screw is such a perfect fit for this it almost self taps it's way in except for a little bit, this is why it's important to tap out JUST one or two threads. No more! Again be careful about chips and clean up when your done.
Step #3: take the 3/16 steel brake line and run the 6 mm die down it about a 1/2 inch, it won't make very deep cuts and that's expected. Remove the die and set aside.
At this point use the tube cutting tool and trim the piece you just threaded so it's about an inch and a quarter long (you will be able to shorten it later if you wish, its easy to do.) It's MUCH harder to stretch steel so it's best to start off a little on the long side.
Step #4: Bust out the JB Weld and mix up a small batch, and apply some to the end of the threaded section of brake line. I also like to take a paper clip and coat a little on the threads that were tapped into the flange as well. What are you waiting for? Screw'er in! Make sure the end of the line (or any JB Weld) DOES NOT intrude into the port going into the diaphragm. It may be loose going in due to the shallow line threads, after the epoxy sets it won't be loose anymore!
After you are done screwing the line in place take the 1/8 drill bit and use it to clean any JB Weld that may have entered the line. You can use a paper clip or a toothpick to clean any epoxy that has entered the port at the base of the flange.
Step #5: Clean the 1/8 drill bit and insert it back into your new port. MAKE SURE IT COMES OUT THE LINE AND HITS THE FAR SIDE OF THE PASSAGE! This is what we are going to use to determine how far to screw in the set-screw. Dab a little epoxy on the set-screw and run it in till its flush with the flange OR it hits the drill bit. If it hits the drill bit and isn't quite flush with the flange don't fret. Just remove the drill bit and let the epoxy dry overnight then just grind off the excess with a benchgrinder, cut-off wheel or dermal tool.
If you did your job correctly this is how the valve should look like- now pressure from the upper intercooler line cannot reach the lower port in the BOV. Installed on the Daytona with the new port open to atmospheric pressure this valve has held without leaking at 30 psi! And the best part is if I want the BOV to be "quick releasing" again (that's the whole point of having that port in the base of the valve from the factory) its a simple matter of running a vacuum line from the turbochargers outlet nipple to the new port and viola'.
Gus Mahon has a nifty diagram on his page showing how you can add a electric solenoid so you can go from quick release to the no leak action at the flip of a switch! (I'm lazy and haven't gotten around to it yet)
A quick tip because this has come up already: The upper part of the B.O.V. MUST AT ALL TIMES be connected to a vacuum/boost source behind the throttle body that has full engine vacuum when the engine is at idle. The new port you just added MUST be hooked to the turbo's outlet barb or somewhere in the intercooling tubing for the BOV to work correctly in fast release mode. Or you could just leave the port open to outside air but you loose the fast release feature which is fun for scaring the hell out of honda drivers ;-)
Pre-modified BOV installed on my Daytona...
A Question from a reader!
Michael asked:
Now for the question, I am looking at the BOV stuff and notice that you have some sort of chrome muffler/aircleaner thing attached to the BOV exhaust hose, what is that thing?
Its a Moroso valve cover breather PN# 68811 with a K&N style element.
And is it necessary?
Sure is! When under cruise or at idle the BOV is open to outside air! So some of the engines air gets pulled through the BOV opening. Without a filter a lot of dirt and debris would get ingested into the engine under these conditions.
when finished it should all look like trinydex's car
Old Apr 6, 2007, 08:53 AM
mitsuorder's Avatar
Hey triny, how is on/off throttle modulation on the highway with this in the car? I ask because when I had my 1st gen valve with the dejon tool leak stop kit the compressor surge was like an elephant kicking the car.
Old Apr 8, 2007, 01:33 AM
vboy425's Avatar
i did this for my buddy. the surges drives me nuts. don't do it.
Old Apr 8, 2007, 09:03 PM
agolgan's Avatar
anybody else done this? just want a second opinion on the surge.
Old Apr 8, 2007, 10:57 PM
mitsuorder's Avatar
I'm not in any way knocking trinydex here but I pretty much blame the premature death of my stock turbo on the surging seen from this setup. So please be careful guys.
Old Apr 17, 2007, 01:54 PM
REVLIMITLAUNCH's Avatar
what exactly is that bottom hole on the evo mr bov exactly for? im using it for a diff application that is not an evo and i just picked it up.
Old Apr 17, 2007, 06:39 PM
CharlieGsanD's Avatar
ive run the LSK with a Greddy Type S & Type R....... Stock 8 turbo & now the 3076 .......no problems with surge or relaibility (aside from greddy's weak diaphragms)
i havent run the LSK with the 1g or EVO bov's but from my fiddling W my setup i imagine the spring rates might be a bit high. if your having surge issues W the LSK then id reccomend sitcking to the adjustable BOV's that incorporate ports to both sides of the diphragm such as the greddy style & lowering the spring preload
Old Apr 19, 2007, 07:46 AM
bump to find this out...
Old Apr 19, 2007, 09:19 AM
it alows the underside of the diaphragm to see boost pressure, counteracting the spring sressure & giving the valve faster response
Old Apr 19, 2007, 08:00 PM
awesome, thank you very much for clarifying it for me. i appreciate it.
Old May 1, 2007, 12:09 PM
trinydex's Avatar
if you set up the leak stop per directions the surging should be minimal... i also am not sure what kind of surging everyone is talking about.
Old May 22, 2007, 01:31 AM
so i got to thinking & figured that if i plumbed the atmospheric refrence port of the Dejon/Gus-mod/LSK into the intake system pre-turbo i would then also have vacum pulling the diaphragm shut when the LSK switched over above 15 psi.
i wasnt expecting much of a change, but after driving with it for a few days & looking at some logs it seems as though the valve is sealing quicker during boost onset/transition into full throttle.
Old May 22, 2007, 08:03 AM
trinydex's Avatar
hwich one is the atmospheric reference port?
Old Aug 23, 2007, 12:59 AM
TwistedEvo8's Avatar
Can anything like this be done to the Stock Evo 8 Bov? (plastic one?) Or Sould i just wait and spend the money on a bov?
Old Aug 23, 2007, 02:04 AM
kmcconn9's Avatar
I have been running the 1g setup for over a year now...its perfect with little to no surge whatsoever...The driveability with this is bov is by far the best on the market when it comes to recirculated with the stock ecu.
Quick Reply: HOW TO: "gus mod" dejon tools leak stop kit (MR BOV!!!)
