apexi tt just FRIED my Evo!!!!
Old Apr 8, 2007 | 01:02 PM
eponti's Avatar
Double check your wiring harness from the TT you might have a short somewhere.
Old Apr 8, 2007 | 01:07 PM
RoBear's Avatar
Originally Posted by mofoSTI
blame apexi!!
I'll sue them for all they're worth!!!
Old Apr 8, 2007 | 01:08 PM
RoBear's Avatar
how could I check for a short in the harness... and why would the car still be acting the same way now that it's uninstalled?
Old Apr 8, 2007 | 01:18 PM
zlancer's Avatar
i believe to get the fuses out of the yellow holder...you pull up on it and it comes up a little but NOT out. then you have to open up the tabs on the sides of the fuse and pull the fuse out of the yellow holder.
Old Apr 8, 2007 | 01:20 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
on my lancer i fried a fuse when installing my alarm that killed everything u just described and i think it was a 7.5 not sure, but if the evo's fuse box is the same as mine i will go out to my car and look for u which one it was. also aren't things under yellow tabs usually airbag stuff?
Old Apr 8, 2007 | 01:53 PM
RoBear's Avatar
thanks for all the help guys. keep it coming.
"on my lancer i fried a fuse when installing my alarm that killed everything u just described and i think it was a 7.5 not sure, but if the evo's fuse box is the same as mine i will go out to my car and look for u which one it was. also aren't things under yellow tabs usually airbag stuff?" I'd love to hear what you find out.
Old Apr 8, 2007 | 03:07 PM
onesicklambo's Avatar
there are ALOT of fake apexi TT's floating around. I am not saying you have a fake one..but id double check. I have heard the fakes can go go out easily.
Old Apr 8, 2007 | 06:52 PM
mitsuorder's Avatar
it's the fuses in the yellow holder that you described, I'll put lunch on it
Old Apr 8, 2007 | 07:52 PM
well i checked it was a 7.5 fuse the one i replaced when i had that issue but w/e i am sure u chked all your fuses anyway.
Old Apr 8, 2007 | 08:45 PM
RoBear's Avatar
okay, so we've narrowed it to the fuses in the yellow holder. But I am still confused on how to remove them. I can get the yellow thing to release part of the way, but then it's stuck. Do I then pull the fuses out with needle nose? Again, thanks for all the help. I don't know what I'd do without y'all. Probably go to the fdealer and get my warranty voided.
Old Apr 15, 2007 | 01:41 PM
RoBear's Avatar
So it turns out that it was just a blown #10 fuse in that yellow casing in the engine compartment. It took a little creative prying with some needlenose pliers, but I got it out, put a new one in, and all the original functions are back to full capacity. I then disconnected the battery, and reinstalled the apexi tt. It works perfectly and I couldn't be more relieved (I know I'm probably an idiot for thinking it was something more serious). Thanks for all the help, gents. Now if I can just figure out how to program this thing... the directions are in Japanese.
Old Apr 15, 2007 | 02:08 PM
mitsuorder's Avatar
Very glad to hear things worked out man The auto funtion on mine never once worked properly. The auto timer function is supposed to allow you to set a minimum and maximum time range for the timer. It is then supposed to automatically select the appropriate time from those two ranges. If anyone else has had this problem and figured out what caused it let us know. Usually just keep mine on the manual setting for 45 seconds.
Old Apr 15, 2007 | 07:55 PM
RoBear's Avatar
^Sweet, but how do I even do that. I can't understand the directions. I played with it long enough to figure out that holding the stick to the left shuts it off, and to the right lets you set it, but I can't figure out the rest.
Old Apr 16, 2007 | 10:55 PM
TempeRacerGuy's Avatar
Here are the directions in english
Apex-I Turbo Timer instructions - English
Old Apr 16, 2007 | 11:14 PM
mitsuorder's Avatar
nice find TempeRacerGuy
