apexi tt just FRIED my Evo!!!!
Old Apr 17, 2007 | 05:06 AM
  #31
RoBear's Avatar
Originally Posted by TempeRacerGuy
Here are the directions in english
Apex-I Turbo Timer instructions - English
Man I wish I had had these for installation Thank you so much, what a find!!!
Old Apr 21, 2007 | 08:29 PM
  #32
trinydex's Avatar
which fuse do you replace if your dome light works but no clock, no radio, no ignition?
i tapped the tt harness for power only (no tt) and i plugged in the gauge without disconnecting battery.
Old Apr 21, 2007 | 08:32 PM
  #33
RoBear's Avatar
Good question. Grab your manual, grab the "fuse grabber" from the fuse box area under the dash, and just start looking for the burned out one. pm me if you have questions
Old Apr 21, 2007 | 09:38 PM
  #34
trinydex's Avatar
i think i need a test light. none of them are "burned"
Old Jun 2, 2007 | 10:09 PM
  #35
cbareng's Avatar
Check the plug at the bottom of the fuse box.....usuall when the underdash panel is removed there is a 10mm bolt srecwed onto the fuse box securing the bottom of the panel, most cases the plug will become loose....I've seen it happen many times.....
Old Jun 2, 2007 | 10:13 PM
  #36
hksevoix's Avatar
edit
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
uneekvisions
14
Apr 8, 2018 08:57 PM
4wheelsqueal
Dec 30, 2011 01:40 PM
Lucas03ES
Mar 20, 2009 11:53 AM
nebolic
Dec 23, 2003 08:42 PM
