How To Install Laile: Beatrush Undertray Mitsubishi Evolution VII-IX
Old May 1, 2007 | 06:28 PM
Faust's Avatar
Originally Posted by EvoAnthony
God I want that nice piece of artwork! My plastic undertray is all beat up...
You gotta link of where you got it?
PM Kami Speed.
Old May 1, 2007 | 07:17 PM
CICreations's Avatar
Originally Posted by Faust
It looks like the driver's side has a black plastic piece that connects it to the under panel and the passenger side doesn't have that? Is it just missing the piece?
Old May 1, 2007 | 09:38 PM
Faust's Avatar
https://www.evolutionm.net/forums/sh...92&postcount=5
Old May 2, 2007 | 05:51 AM
^^lol, roger that, where do you get the extender pieces?
Old May 2, 2007 | 12:51 PM
PibusEVO's Avatar
*When you buy the SE lip there are also 2 oem extensions that you need to purchase to match up to your factory underpanel since the SE Lip is a good bit lower then the standard lip. There is nothing to be fabricated they are all OEM parts.
*Yes, you need to re-use the factory plastic rivets for the front of the under panel to the lip connection.
*I have the Ebay Exhaust Downpipe. Clears just fine.
*Hondafan you can have a ride any time you want!
*I have the cusco braces and they fit fine. I stated that in the above how-to:
"Next remove the 2 large bolts that hold your front OEM or Aftermarket Chassis stiffening bar in place (One on each side). And install the Beatrush Undertray Brackets so that the lower end w/ Welded Nut is facing forward (see Diagram, Bottom of Illustration #3). If you are using an Aftermarket Chassis Lower Arm Bar such as the Beatrush or Cusco and are using spacers install the Beatrush Brackets underneath your spacers so the rear of the tray doesn’t rattle!"
Can you help me by telling the part numbers of these extensions? Or at least where did you bought them. I'm desperate to find these stupid parts.
Thanks
mlocatel
Old May 20, 2007 | 10:48 PM
Laxman's Avatar
Is it supposed to look like there is a big gap between the undertray and the bumper?
Old May 21, 2007 | 02:19 AM
Faust's Avatar
Do you people even read the threads you click into?
Old Jun 19, 2007 | 05:45 AM
timmiii's Avatar
Does this undertray work with the Voltex front bumper?
Old Jul 27, 2007 | 12:50 AM
MTRJunior's Avatar
PM "Spins4" if you want to buy the plastic extensions needed for the SE lip...hes a part manager at a mitsubishi dealer and he will give you a good deal on OEM parts
Old Jul 27, 2007 | 08:05 AM
Balrok's Avatar
Just installed this last night, didn't have to extend or install anything extra for it to fit an SE lip, however i'm not sure bout the Vol. Fit was perfect for me though
Old Jul 27, 2007 | 08:58 AM
Faust's Avatar
Yeah, That's right...B/C you already have the extensions from the factory since you have an OEM SE...They are the things pop rivited onto the lip already.
Old Aug 2, 2007 | 05:44 AM
blair260's Avatar
Hi guys, can someone tell me where I can get this undertray from?
Old Aug 6, 2007 | 08:42 AM
EvoEntropy's Avatar
very nice write up
i just got mine delivered
it will be for my 8 and will be putting it on soon
I might eventually get the ings +1 kit, and i hope this will fit with it
I ordered mine from rallysportdirect
Old Aug 7, 2007 | 06:59 AM
Sap12687's Avatar
To anyone who has this installed....would you say it provided an extra element of rigidity to the front bumper?
I ask because i just put on an APR GT front bumper and Im not running my OEM undertray and I feel the need to stiffen things up a bit and I want to know if the addition of this piece would give me what im looking for.
Thanks!
Old Aug 7, 2007 | 07:41 AM
Faust's Avatar
Yes, When I installed mine I felt it made the bottom pretty rigid. Good Luck.
