Idler Pulley/Accessory
Old Jun 6, 2007 | 09:21 AM
mdsevo06's Avatar
I tried to remove my Idler pulley, this is the accessory one that is just the pulley and a bolt. The problem is the bolt is long and runs in to the frame before it comes out of the block. Is there a trick to removing this, do I need to remove the front and side engine mount to drop it enough, to slide the bolt out?
Any help would be appreciated.
Old Jun 6, 2007 | 10:27 AM
mdsevo06's Avatar
Bump but not forgoten
Old Jun 19, 2007 | 02:40 PM
mdsevo06's Avatar
Bump for some help
Old Dec 17, 2013 | 03:16 PM
w evo's Avatar
6yr bump...does anyone have a trick for doing this easily?
Old Dec 17, 2013 | 03:24 PM
mdsevo06's Avatar
There is no quick way about it, you have to remove the passenger side engine mount and the front engine mount with the engine on a jack (use a piece of 2x4 under pan to displace load). Lower it slightly to access the hardware to the pulley.
Old Dec 17, 2013 | 03:31 PM
w evo's Avatar
I was afraid of that. Thanks, man!
worthyking
10
Aug 21, 2023 08:37 AM
marinejensen
Jun 24, 2015 01:58 PM
Darkn3s
Apr 25, 2013 02:46 PM
apiazza2010
Sep 6, 2012 08:51 PM
anthonypazsd
Jan 31, 2010 03:01 AM
