What is the Best Way to Install Engine ???
Old Jun 22, 2007 | 08:57 AM
Johnboy1065's Avatar
Was wondering if you all have any tips on the best way to install the engine back into the car. I took it out through the bottom. Any tips about how to make the transfer case fit in there easier??? I remember that sucked getting out. I plan on going through the bottom again with the transmission already attached to the block. I'm just thinking it might be hard to fit the transfer case in there after the engine is in the car. So should I not fasten any motor mounts and just have the engine hanging there and put the transfer case in place before I lower the engine and put it on it's motor mounts??? what ways have ya'll done it??? Also is it easier to put the intake manifold on it after the engine is already in the car or is it best to do it before??? And abou the rear motor mount. most of you know its horrible to get to.
Any tips would be appreciated!!!
Thanks,
John
Old Jun 22, 2007 | 09:26 AM
bump
Old Jun 22, 2007 | 09:47 AM
Wallesasuaz's Avatar
shouldn't the engine be removed through the top using a cherry picker thingy..
Old Jun 22, 2007 | 10:37 AM
Nesiop's Avatar
Either way works.
TCase will probably need to be put on without the engine.
Attach tranny to motor and drop the motor in, then slide the tcase onto the propellor shaft and then to the tranny.
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
54
Mar 13, 2017 01:27 AM
Sethlans
Jun 21, 2015 09:47 AM
teameditevo08
Dec 29, 2012 04:53 PM
CooleyKing
May 18, 2010 01:00 AM
scherejs
11
Aug 15, 2005 07:16 AM
