Transmission and Transfer Case
Old Jun 23, 2007 | 09:57 AM
J-ROC's Avatar
Does anyone have an idea how to change the transmission and transfer case fluid? is there a DIY thread? Please Help.....
Old Jun 23, 2007 | 10:10 AM
evo8fl's Avatar
transmission: take the air box off, lay down in front of the car u r going to see the 2 bolts
tc: lift the car on the passenger side to get to the bolt on top the tc
Old Jun 23, 2007 | 11:18 AM
J-ROC's Avatar
you don't have pics of where to drain, and fill?
Old Jun 23, 2007 | 11:21 AM
bhamEVOguy's Avatar
which car are u reffering to?
an evo or a bmw because it says u drive an E430
Old Jun 23, 2007 | 11:24 AM
J-ROC's Avatar
Its for my EVO. I know it says I drive a MB E430, but thats the family car. I had to get a toy for myself. I'll update that right now.
Old Jun 23, 2007 | 11:27 AM
bhamEVOguy's Avatar
gimme a few mins. i'll get some pics.
Old Jun 23, 2007 | 11:28 AM
J-ROC's Avatar
cool thanks.....
Old Jun 23, 2007 | 11:33 AM
bhamEVOguy's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=75589
i think u'll find most of it in here. if u need anything else, lemme know
Old Jun 23, 2007 | 11:34 AM
bhamEVOguy's Avatar
i just did mine yesterday.
oh and a 15/16 socket works better than a 24mm.
Old Jun 23, 2007 | 11:37 AM
J-ROC's Avatar
hey thanks for the pics bhamEVOguy. I was just wondering, what kind of fluid did you use for the transmission and the TC. How much do you need? Do you need some kind of pump to fill it back up?
Old Jun 23, 2007 | 11:41 AM
bhamEVOguy's Avatar
i used royal purple for the transmission ---- 3 qts. or till it starts to drip out of the fill plug.
and diaqueen lsd for the tcase and rear diff. ---- fill till its full.
and yes u need a pump to fill it back up.
u can get a pump from ur local autostore. get a plastic pump with a tube.
Old Jun 23, 2007 | 11:44 AM
bhamEVOguy's Avatar
get a pump like this
https://www.evolutionm.net/forums/at...3&d=1067788603
Old Jun 23, 2007 | 11:45 AM
bhamEVOguy's Avatar
here's a better pic of the tranny fill plug
https://www.evolutionm.net/forums/at...4&d=1067788994
Old Jun 23, 2007 | 03:08 PM
J-ROC's Avatar
what is the grade for each fluid.
Old Jun 23, 2007 | 08:22 PM
RedV's Avatar
I use Penzoil Synchromesh/GM Syncromesh in my Evo 5 Speed... been happy with it so far.
BUT!!!... since it looks like you have an MR, I would recommend ONLY using the genuine Mitsubish Super Diaqueen in your transmission. Mitsubishi specifies this fluid for the 6 speed MR transmission because of the lower tranny oil capacity and more heat. It's pricey... but it's the right stuff. It can be purchased here...
http://www.lancershop.com/customer/p...&cat=15&page=1
For the transfer case use ONLY genuine Mitsubish Diaqueen. It will say Mitsubishi Diaqueen LSD Gear Oil on the can.
Also use ONLY the same Diaqueen for the rear differential. It can be purchased here...
http://www.lancershop.com/customer/p...9&cat=0&page=1
... or a number of other places.
Also note, that while the tranny drain/fill plugs are in approximately the same location on the MR transmission, they are torx type plugs and not the ones you see in the pictures of the 5 speed Evo tranny.
Hope that helps.
