HELP: Aeromotive Eliminator Relay
Old Sep 10, 2007 | 08:49 AM
Nesiop's Avatar
Does anyone happen to have the Devo Tuning Fuel system?
The kit I am installing has the new Aeromotive Eliminator Fuel pump/relay.
I am not the best with Relays but can do pretty decent as I have installed a couple different Alchy systems with Relays.
The kit I got was missing "in aeromotive terms" "30 AMP Circuit breaker" which I am assuming is this: http://www.radioshack.com/product/in...entPage=search
Correct?
Then looking at the instructions from Aeromotive: http://www.aeromotiveinc.com/pdf/16301.pdf
I see this wiring diagram.
Now can anyone explain in Evo terms where each one of the wires on the relay should go on the evo?
Thanks in advance.
Old Sep 10, 2007 | 10:20 AM
Nesiop's Avatar
ttt
Old Sep 10, 2007 | 11:48 AM
awdboosted's Avatar
87 - Fuse power from Battery
86 - Power from fuel pump harness
85 - Ground any where
30 - + power to fuel pump
Ground for fuel pump to chassis
Very forward if you look at the top diagram on the relay.
Old Sep 10, 2007 | 11:56 AM
Nesiop's Avatar
Hmm 85 looks like either +12 power source switch (I guess an on off)
87 - Appears to go to Fuel pump.
86 - Appears to be a ground
30 - goes from relay to battery with that radio shack part.
Old Sep 10, 2007 | 05:30 PM
Nesiop's Avatar
ttt
Old Sep 11, 2007 | 04:55 AM
Nesiop's Avatar
Bump
Old Sep 11, 2007 | 12:59 PM
Nesiop's Avatar
bump
Old Sep 11, 2007 | 04:04 PM
Nesiop's Avatar
Anyone else, or someone to verify with AWDBoosted as his numbers dont seem to match my diagram.
mrfred
383
Jul 16, 2024 09:29 PM
Biggiesacks
Sep 13, 2016 06:43 PM
dudical26
13
Jul 9, 2008 08:01 AM
Paul Nelson
10
Aug 3, 2007 05:20 PM
