DIY Ground Kit for $20
Old Jul 13, 2003 | 11:35 PM
SilverEvo8owner's Avatar
the previous post was my brother
i did not ground the tranny
why would you?
1. i have wire running to body right beside the air box and in fornt of the fuse box. I also removed the paint between the other grounds and the body
2. i have a wire running to the firewall were the strut bar connects. I used the driver's side bolt. From the bolt i ran a wire down to the intake manifold were there is an existing ground. This is a small ***** wire.
3. i have a wire running to the back hoist eyelet connected to the block. From that i ran a wire to the top mounting bolt of the alternator. You can loosen this bolt without taking hte belt of and dont worry about the alternator moving.
4. (I just did it for the hell of it) i ran a wire to the left side were the strut bar is bolted to the strut
Also on the number 3 wire i ran a wire from the back hoist eyelet to the front one.
i noticed a big difference in the idle paticularly with the a/c on
it also pulls a lot harder throughout the revs
i am very happy with mine!
Old Jul 14, 2003 | 01:56 PM
bpclements's Avatar
do you have any pics of the extra wire coming off of number 3
Old Jul 14, 2003 | 05:12 PM
bpclements's Avatar
Originally posted by JWERNER24
that truck next to you guys is hot.... ;-)
Yeah that truck actually belongs to one of my friends, lol.
Old Jul 15, 2003 | 01:26 PM
bishiboy's Avatar
wire routing
This pic is one of reasons I ran to the Tranny..
Old Jul 15, 2003 | 03:52 PM
jemm's Avatar
Excellent post... mods consider moving this to the "howtos-installations" /hope this does not get lost in the sea of other engine related posts.
Bishi,,,, you rock!
Old Jul 15, 2003 | 04:06 PM
jemm's Avatar
One important Question though.... can the plastic insulator on these speaker wires stand up to the evo's engine bay temps?
Old Jul 15, 2003 | 05:10 PM
bpclements's Avatar
I know that they can withstand the high temperature of a propane solder torch heating up the terminal. The heat is transfered throughout the entire wire and those things get really hot, at least 660 degrees to melt the solder!!!!!! So if your evo runs that hot you are in some trouble, lol. By the way you should only invest in the high current 4 Gauge wire. It is the ones that bishiboy and I used on our EVO's.
Old Jul 15, 2003 | 09:28 PM
jemm's Avatar
cool!
Old Jul 15, 2003 | 09:42 PM
once i find my digital camera ill take a picture of the extra wire coming off three
but i dont see any point of grounding the tranny
Old Jul 15, 2003 | 09:51 PM
bpclements's Avatar
Well I guess as along as you ground some where on the block you will be good since all of that stuff is bolted pretty tight. Hey, the more the better right. It was easy for me to do so I did it.
Old Jul 20, 2003 | 09:34 AM
Rob W.'s Avatar
I'm new here, so bear with me... but what is the point of all these grounding kits? I'm not sure how it could smooth out the idle or improve the acceleration.. that is, not unless the electrical harness is grossly misdesigned from the factory.
Old Jul 26, 2003 | 12:09 PM
Kinmar_X's Avatar
Did you have to buy a bolt to ground to the tranny? If so what size bolt did you have to use.
Thx
Kevin
Old Jul 26, 2003 | 04:06 PM
xtnct's Avatar
Well, I don't know how you got to do your kit for $20. I went to a stereo store and they charged me $16 for 8ft of 4 gauge wire. They wanted $4 for 2 gold plated eyelet connectors. I backed out of the deal and will try pep boys or the like to get some cheaper copper ones or something.
Did you know someone at your stereo store that you managed to source your parts so cheap?
Old Jul 26, 2003 | 05:59 PM
hardcoretuner's Avatar
great post i own a oz lancer and i think i might try diy on this project also, if i do i will post the lengths later
thanks a lot great great post can't say it enough
Old Jul 26, 2003 | 08:47 PM
Kinmar_X's Avatar
Just did this today to my evo. Below is what i paid
9 feet of 4 guage wire = $11.07 (local electronic shop)
12 Gold ring terminals = $29.94 (4.99/pair @ Circuit City)
1 bolt for tranny connection = $ 0.11 ( local hardware store)
Total: $41.12
