FP EVO Green 20g-lt request
Old Oct 28, 2007 | 12:19 PM
FastAzzEvo's Avatar
Anyone have a how-to on this? I was trying to figure out the quickest way to tackle this..
Pulling the fans and radiator seems more steps, but less time in the end.
Old Oct 28, 2007 | 12:24 PM
AF-Evo8's Avatar
when i did my evogreen install i drained the radiator/oil, and took the radiator/fan out as one piece. this made much less of a mess and made it super easy to take my stock turbo out w/o removing the manifold. make sure you have a drain pan under the turbo for the coolant/oil that will drain out of the feed/return lines. if you have any q's during the process feel free to pm me and i will help you in anyway that i can.
also make sure you have new copper washers for the oil feed @ the head and the oil return gasket at the oil pan.
Old Oct 28, 2007 | 12:26 PM
AF-Evo8's Avatar
it only took me 2 1/2 hours and i re-torqued everything after a couple of test runs to set my MBC.
Old Oct 28, 2007 | 01:04 PM
EVO8904's Avatar
Yeah, it took me about 2 - 2 1/2 hours. I left the radiator in but you have to drain the radiator and oil.
Old Oct 28, 2007 | 05:20 PM
FastAzzEvo's Avatar
Ok cool, I'll do that then..
Does ya'll have a parts list of gaskets and washers that I will need?
I'll have to order this stuff ASAP, because the turbo is going on next weekend.
I assume, there is 2 copper crush washers per hose, i.e. coolant and oil..
then I'll need a new gasket for the oil return, if it is like my talon.
I'm doing a MR o2 housing also during this time.
I also will pick up another donut gasket since i've taken my downpipe off a few times already.
Old Oct 28, 2007 | 05:41 PM
AF-Evo8's Avatar
i took the radiator out just to prevent any damage when putting in the turbo.
Old Oct 28, 2007 | 05:58 PM
AF-Evo8's Avatar
http://www.slowboyracing.com/estore/...2&bestseller=Y
2 x 14mm for oil feed on turbo
4 x 12mm for coolant feed/return on turbo
2 x 10mm for oil feed off head
http://www.slowboyracing.com/estore/...productid=1872
oil return gasket for oil pan.
somebody correct me if i'm wrong on the sizes
Old Oct 29, 2007 | 05:32 AM
FastAzzEvo's Avatar
thanks for the info....
Old Oct 29, 2007 | 05:40 AM
evo@24psi's Avatar
Thankx Also! Will be doing just a 9 swap next week.
Old Oct 30, 2007 | 06:10 AM
FastAzzEvo's Avatar
would it be wise to replace the exhaust manifold gasket and the turbocharger gasket.
Also, the air outlet fitting gasket?
Would any of these be reusable.
Old Oct 30, 2007 | 07:06 AM
MR Turco's Avatar
I would always replace the head -> exhaust manifold gasket. While I would normally recommend replacing ALL gaskets the OEM gaskets are the most diesel gaskets i have ever seen. They feel like solid lead.
You most likely can reuse them but I got the header, turbo to header, o2 housing and donut gaskets for like $40 at a local dealer with EVOm discounts. it is nice insurance just doing them all once and not having to worry about them. But i have heard the o2 housing, donut and exhaust mani to turbo gaskets can be reused.
Old Nov 3, 2007 | 06:04 AM
FastAzzEvo's Avatar
got all my gaskets and everything. the only thing I didn't purchase was the o2 housing bolts. Someone said I would need them
I am going to begin the install today and hopefully everything will go well.
Anything I should know, maybe make things easier?
Old Nov 4, 2007 | 11:11 AM
FastAzzEvo's Avatar
If you doing this swap on a car with factory o2 housing. I would suggest taking the o2 housing somewhere to get the o2 sensor out.. I finally got mine out, but it was a PITA.
My initial impression was it seems to take longer to spool, but then again I haven't really went full throttle.
Denzi_92
Pacific Northwest
Jun 6, 2016 07:52 PM
custompaint
Feb 8, 2016 12:17 AM
matx
South Region
65
Jan 11, 2016 10:43 PM
Teal2nnr
Sep 23, 2009 08:42 PM
