Has anyone taken out the clock yet???
Old Jul 31, 2003 | 09:38 AM
Eric Lyublinsky's Avatar
Hey All,
Installing a Greddy boost gauge this weekend.
I have installed Defi's off the clock in my WRX and they worked great! It had the four wires needed 12v constent, 12 ing on, ground and light. Does the EVO have the Same set up???
How do you remove the clock?? Do you need to take out the whole ducting out??
Any help would be great.
I will post pictures and a full install for everone to see after I'm Done.
Thanks
Eric
Old Aug 1, 2003 | 11:50 PM
kgmm's Avatar
For the evo, you would be much better off using a fuse tap to get the ignition 12v signal off the fuse box. And the constant 12v and illumination from the radio. I had a wrx as well, I certainly understand how convinient it was to be able to get all you need from the clock.
edit: to get to the clock, you need to the center panel out first (where the radio is). Pull the 3 knobs out, undo two screws, and then carefully pry it out as it is being hold down by clips. Once you do it, you will see another two screws for the upper panel (the long one with the clock). Undo those and you are set.
-Kenneth
Old Aug 4, 2003 | 07:20 AM
-Kenneth
Thanks for your help. The clock wires worked great. Very nice and clean install. No Problems yet and the Greddy gauges have always bin dead on for me. One thing is fishing the wire throw the firewall. It's a pain compared to the WRX.
I have to comment on the build quility of the EVO it's much better then the WRX. I really think it's a tank. good job .
I was very worried about that.
Eric
Old May 12, 2010 | 12:40 PM
D-Mon3y69's Avatar
damn this was a pain to find, took forever to search it up, bump for some good info
JDMevoBOOST
16
Oct 9, 2011 11:18 PM
dsm_mikey
19
Oct 16, 2009 10:30 AM
unleashed91
Jun 26, 2008 10:46 AM
rawkus
Jun 24, 2008 11:26 AM
EvoRSfor060
Dec 8, 2005 02:10 PM
