Request: Replacing Valve Cover Gasket and Spark Plug Seals
Old Mar 24, 2008 | 11:25 PM
omniprobe's Avatar
I am pretty comfortable about doing this after watching the vid and some pictures of cam install. I just wanted some tips or precautions I should take. Or if you can details of the job if you did it before.
thanks
Old Mar 25, 2008 | 11:50 AM
omniprobe's Avatar
anyone?
Old Mar 25, 2008 | 07:26 PM
sekula's Avatar
It's not hard. Took me about 30 mins calmly. Just disconnect everything off your valve cover and just slowly take it off. It may be a little stuck so just keep pulling and it will come off, unless it's obviously stuck on something. Then, just take off your old gaskets and take off the little goo everywhere left from the old gasket, and snug the new gaskets in the valve cover, and put some gasket sealant on the corners and other areas where needed, and you're set. Set it back down and tighten accordingly.
chdvg
Oct 19, 2016 01:17 AM
RunRunRun
34
Mar 9, 2009 05:50 PM
crcain
Jun 6, 2008 02:31 PM
recompile
168
Jul 3, 2007 09:34 AM
kromix
Jun 7, 2004 04:00 PM
