Boost gauge errors
Old Apr 23, 2008 | 01:23 PM
slikdzigns's Avatar
Question Boost gauge errors
Recently I relocated my MR gauges to the A pillar. I had to add about 4 feet of vacuum line to the original gauge. I didn't see any way to calibrate the gauge but it is reading way below normal. Does the length of hose affect vacuum/pressure readings? The only reason I kept the stock MR gauges up to this point is because I bought an avic d3 (which is still sitting in the garage waiting for the orbital double din V2 - but that another thread all together ) and have to wait to get the Defi red racer gauges i want (so expensive! ). Is this error in the readings going to be with me until i replace the gauge with a better one?
Old Apr 23, 2008 | 01:43 PM
Mr. Evo IX's Avatar
No, but maybe your splice is leaking. The stock gauge line has a restrictor T where it connects to the manifold to protect the gauge I guess. I ran into a problem with my aftermarket gauge but not my stock one.
Before you start your car is it on Zero?
Once you start your car how much vacuum does it read?
What does it read at full boost?
Old Apr 25, 2008 | 12:13 PM
slikdzigns's Avatar
When the car is off the gauge reads 0. But when I start it at idle iit reads 50 cm/hg of vacuum which is about 20 in/hg. Full boost reads .7 bars; about 12psi. Totally abnormal. I'll check the line for a leak, but i haven't touched the original line, simply added line.
Old May 3, 2008 | 02:36 PM
Jon91TSi's Avatar
I just noticed the restrictor in my line today and yanked it out.. The stock gauge was very sluggish with it in.. Would this cause any problems with leaning out, etc? Maybe I will log a few runs with the wideband to verify.
EVOpena
Jan 25, 2014 05:21 PM
mattchan99
23
Jan 10, 2014 04:28 PM
racer135
Feb 16, 2008 04:10 PM
wiseguy9
Dec 12, 2006 06:50 PM
evo8forme
11
Aug 16, 2005 10:08 AM
