Need help with Defi boost gauge
Old Dec 12, 2006 | 12:51 AM
wiseguy9's Avatar
Ok guys after a lot of procrastination I installed my defi boost gauge and link on my evo MR. I tapped the pre existing vacuum line from the factory boost gauge. Problem is when my car is at idle it only reads about 15cm/hg vacume instead of like 40 before I installed the defi boost gauge. However when I go into boost both gauges read accurate 1.35 Bar in 6th gear.
Please help me, I do not think the line is kinked because it reads boost fine just not vacuum.
Old Dec 12, 2006 | 10:26 AM
wiseguy9's Avatar
Update, both gauges are reading boost accurate, about 19-20 psi in 6th gear.
However my mitsubishi boost gauge is not going into vacuum at all, and after say going to 15 psi the needle slowly drops to about 5 pounds and stays there when the Defi boost gauge is in 25 psi vacuum.
Thanks
Old Dec 12, 2006 | 10:50 AM
Aux.'s Avatar
The Mitsu gauges are kinda crappy man and i wouldn't worry about it "not reading 40", the standard for vacuum is about 15 depending on your altitude, so don't worry. The only question i have is why are you using your pre-exisiting tap.....there are plenty of "How To's" that show different methods to where to tap in at.
Old Dec 12, 2006 | 10:54 AM
skywestseth's Avatar
Yea why do you need two boost guages???
Old Dec 12, 2006 | 01:44 PM
wiseguy9's Avatar
Ok now the Mitsu boost gauge is not going below .5 bar, guess I will be looking for another vacuum source. What is the cleanest place to get a vacuum source, only one I know off hand is FPR.
Thanks guys
Old Dec 12, 2006 | 01:46 PM
Aux.'s Avatar
Dude, look in the "How To" section. I know there is one there, and i bet it has pictures too.
EDIT: Alright dude i am back, and here is the link for exactly what you are asking for, and like i promised......it has pictures. You gotta learn to search man......or your gonna need a fire retardant suit.
https://www.evolutionm.net/forums/sh...+gauge+install
Old Dec 12, 2006 | 06:50 PM
ak47po's Avatar
Read this.
http://evomoto.com/tech_info.php?tPa...8749bf49d175d4
slikdzigns
May 3, 2008 02:36 PM
racer135
Feb 16, 2008 04:10 PM
EVO8LTW
Nov 23, 2004 08:04 PM
The Emperor
Sep 4, 2004 01:13 PM
SillySpheres
Northeast Region
Sep 19, 2003 10:22 AM
