Dash Lights NEED HELP PLEASE
Old Jan 10, 2010 | 09:55 PM
D1no's Avatar
To those that had this problem, what did you do to fix it?
Im having the same issue. This was after installing my Alpine 9887 which replaced another Alpine 9830. The old alpine harness didnt fit so I had to wire in the 9887 harness. My 04 ralliart has similar wireing as the Evo. I do have the other dash lights working. Oil, bat, seatbelt, door symbols light up.
I checked the fuses under the hood and the fuses under the dash. I did have the radio fuse blown and replaced it.
The Mitsu harness has a solid orange wire that I connected to the Alpines solid orange wire. I am not using the the orange blk wire and taped it up. My Mitsu harness does not have an orange white wire. This orange blk wire may have been connected before so this might be my problem. If I were to connect it up, do you know were it should go?
Any thing else I should look at or double check?
Thanks
Old Dec 9, 2013 | 01:38 PM
RallyRed4g63's Avatar
Hey i know this thread has been dead a while, but i just got an evo8 and am doing the hvac relocation. I rerouted everything and got the new hvac setup, but only one of my lights turns on. Like all the orange lights for the a/c and defrost turn on, but only the right little green lamp behind the faceplate lights up, the drivers side does not. Ive checked the plugs and they are all connected, i would assume it wouldnt be a fuse if one turns on but not the other? Not a huge issue but im bery meticulous about things like that. Any help would be appreciated
LewisLancer
Lancer How Tos / Installations
Nov 17, 2016 09:42 AM
MharAndal
Sep 8, 2013 09:01 AM
ahr4156
Jul 7, 2012 08:43 AM
roblaza
Mar 19, 2012 10:25 AM
benji
34
Jun 4, 2009 07:31 PM
