someone help with clutch install please!
Old Aug 31, 2003 | 11:01 PM
SaitouhHajime's Avatar
Alright, I have taken everything off, all the bolt's to the transfer case, everything, but it will only move about 1/2 inch, just enough to see the flywheel, could someone who has done a clutch install before please help me and tell me why the transfer case won't come off.
Thanks in advance.
Old Sep 2, 2003 | 07:50 PM
ou812's Avatar
Did you release the throwout bearing ? Also , You may have to do some prying , b/c one of your studs may be stuck . Being able to lift the engine up and down helps .
Old Sep 3, 2003 | 06:28 PM
lose2abmw's Avatar
I am in the sxact same position, and I know what I am doing!! I have been going for like 2 hours and now can go no further. The front final drive will not seperate from the transmission. I have all the bell housing bolts out, all of them. Help us out!!
Peter
Old Sep 4, 2003 | 05:12 AM
2Cool's Avatar
You need to pull the stub axles (no idea what the real name is, sorry) as well as the external axles. My mechanic had the same problem, treating the Evo like a normal AWD DSM... they are different. Basically the stub axles are held in by a tension ring type arrangement, and a slide hammer type puller will pop them out. You won't get the case off till they are out, though you can move it back and forth almost an inch.
Old Sep 4, 2003 | 05:20 AM
nastea's Avatar
i thought you needed a slide hammer ...
Old Sep 4, 2003 | 02:45 PM
ou812's Avatar
803 407 9360 . You peeps can call up until midnite EST , after that I will NOT be very hospitable . Mi llama es DAVID . ( Ask for David ) .
Old Sep 19, 2003 | 08:46 AM
broken's Avatar
sorry to be bringing up and old post but.. what is the easiest way to reinstall the throw out bearing? Does it need to be stay attached to the press. plate, and then the release lever somehow attached once the trans. is in place, or does it get connected to the release lever then pressed into the press. plate once installed?
Old Sep 19, 2003 | 12:51 PM
ill born's Avatar
I'm going to need a little help too! I'm about to dive into this project and i read a post last night about draining the coolant? If there is any little details you guys can think of to make this go a little easier please let me know! I would greatly appreciate it!
Old Sep 20, 2003 | 04:18 PM
lose2abmw's Avatar
Call David. He knows the best. You dont drian the coolant. It is really straight forward except for the shaft pulling and the release bearing. Peter
Old Sep 21, 2003 | 10:47 AM
ou812's Avatar
Yes , you must attach the T.O. bearing to plate , then reattach the lever .
Old Sep 22, 2003 | 03:04 PM
broken's Avatar
actually you need to attach the TOB to the release lever, then upon the first clutch depression it will re-engage the press. plate.
Evo-Ninja
Mar 1, 2015 03:48 PM
Bloomie
Oct 21, 2007 08:14 PM
228BlackEvo
Jul 5, 2006 05:36 AM
allWILLdrive
Aug 27, 2003 02:06 PM
gvr4v
11
Jan 11, 2003 11:07 AM
