Wideband O2 sensor install
Old Jun 13, 2008 | 10:10 AM
  #31
Slick-IX's Avatar
Originally Posted by Nevonate
Anyone?
i grounded mine to teh bolt that is located right behind the fuse box (inside the car) you can actually see that the blot already has a couple of cables connected to it which are grounds, i belive coming right from the enginebay
Old Jul 27, 2008 | 10:33 PM
  #32
TurboTylerIX's Avatar
Wiring Innovate LC-1
Just finished wiring my LC-1 tonight and thought I would share how I did it.
I grabbed the 12v switched power from the passenger side kick panel area. I popped off the lower door sill plastic, then the kick panel plastic. Behind the plastic kick panel, there is a white wire harness connector for the power windows. It's the uppermost connector. There is a heavier gauge yellow wire coming off the connector. It is a switched 12v. I used a yellow T-tap to grab power from it and ran my own red wire under the carpet over to the center consol area where I located my LC-1.
Attachment 122418
For the ground, I crimped the blue, white, and black (calibration wire) together into a single eyelet that I grounded to a bolt behind the center consol plastic under the glove box.
Attachment 122438
Side note: I wouldnt use the cigarette lighter for power because it is accessory power. It is powered when the key is turned to accessory. So, while you are sitting there with your car off listening to your stereo, your lc-1 will be on and sensor heated up. Its not the end of the world if you wire it that way, but this way is better and just as easy.
Attached Thumbnails Wideband O2 sensor install-switched-12v.jpg   Wideband O2 sensor install-ground.jpg
Old Sep 26, 2008 | 08:41 AM
  #33
fostytou's Avatar
EvoM Community Team
Attachment 122418
Attachment 122438
Thanks for the pics!
Only thing I would say about your power location is that the SAS system will keep power going to that yellow wire until ~3 minutes after your car is off or after the car is off and you open the door. Just something else to keep in mind!
Old Sep 26, 2008 | 08:42 PM
  #34
NewEvolutionIX's Avatar
I have a DC downpipe that has the cat delete. And at the end of it it looks like it has a perfect spot for a wideband 02 sensor? Its about 19 inches from the cat o2 sensor, would that be a good place for the wideband o2 to get a good reading?
Old Sep 27, 2008 | 09:37 PM
  #35
shangai's Avatar
perfect idea man!
Old Oct 8, 2008 | 05:42 PM
  #36
Powahousealex's Avatar
niice install
Old Oct 10, 2008 | 05:05 AM
  #37
DIDYSIS's Avatar
thanks for the info
Old Oct 22, 2008 | 07:03 PM
  #38
billsIXmr's Avatar
nice install
Old Nov 12, 2008 | 07:49 PM
  #39
stockEvoIX's Avatar
I think the sensor needs to be installed between the 11 and 2 o'clock positions. Your O2 looks like it's at 9. Probably best to weld in one at 12 o'clock like the pics on this forum. Also looks like the 12 o'clock keeps things outta the way prett well too.
Old Jan 3, 2009 | 01:24 AM
  #40
EGHBauce's Avatar
Problems!!
Everything is hooked up. Except I only did the power and ground wires.
On the little sheet it came with it said nothing about tapping into the ecu so I left those wires alone.
It turns on but it will read 11 then slowly it will climb to 19.2 and then just stay there. Driving around did nothing. I did not calibrate it because I was unaware until I read this thread.
Any suggestions?
Old Jan 10, 2009 | 08:53 AM
  #41
hlm's Avatar
hlm
nice job.
Old Jan 10, 2009 | 06:03 PM
  #42
silver3g2000's Avatar
Anybody know how hard it is to connect the wideband to the AEM EMS?
Old Jan 10, 2009 | 06:04 PM
  #43
Mine is hooked up but the EMS isn't reading the output from my wideband for some reason. I'm stumped
Old Apr 30, 2009 | 02:08 AM
  #44
mlocatel's Avatar
To the expert following question
I've mounted mine in these days. The sensor is working, although I see some issues .
Basically the signal is oscillating between 12.5 and 14 (Logworks) and at stand (so where it should be controlled to 14.7 it shows 13.
Do I have a grounding problem??
I'll try to use another place to ground (currently the reinforcement bar above the ECU), but if you know more, please feedback
BR
mlocatel
Old Sep 8, 2009 | 03:52 PM
  #45
SWOLN's Avatar
Attachment 122418
Attachment 122438
Do not use the yellow wire in that picture for power it will result in a SRS light, and as of now (09/08/09) Evoscan can not clear the air bag codes. You will need to go to Mits to clear this code.
