problem after mbc install
Old Jan 7, 2009 | 07:32 PM
91 TURBO's Avatar
Question problem after mbc install
so i just did the full 3" turbo back. no problems there. then a few days ago, i did a turbo xs mbc. i've got it set to 20-22 pounds of boost. it runs smooth until 19 pounds then it bucks one time, and keeps building boost until it spikes then tapers off to 16-18 pounds. im not concerned with the tappering off of the boost. what could be causing that bucking? any comments would be great. thanks.
Old Jan 7, 2009 | 07:34 PM
LI Pinky's Avatar
the bucking could be boost cut...not sure.
Whats your mod list and are you tuned?
Old Jan 8, 2009 | 06:19 PM
91 TURBO's Avatar
intake, full 3" turbo back, greddy type-s(one spring). and i'm untuned.
Old Jan 10, 2009 | 09:05 AM
hlm's Avatar
hlm
i would recommend a boost leak test for the boost spikeing.
Old Jan 10, 2009 | 12:22 PM
91 TURBO's Avatar
thanks. but im not worried about that for now. only the bucking of the car.
Old Jan 11, 2009 | 10:44 PM
chaotichoax's Avatar
do not increase boost levels without being tuned
Old Jan 15, 2009 | 06:42 AM
Fknfstevo's Avatar
^The post above me, read that modding for dummies. No offense. But you should not install an MBC without a tune. If it is bucking around 5500-6000? If so are you still using your stock plugs?
Old Jan 15, 2009 | 07:02 AM
skatermsmn's Avatar
Get tuned, its probably boost cut. I had that problem and it was solved after I got tuned.
Old Jan 19, 2009 | 05:52 AM
Turbodemon's Avatar
boost cut i say i have the same thing it bucks wild and kills all the fun.
i got it after adding the final piece to my turboback setup.<----o2 housing
Old Jan 19, 2009 | 06:00 AM
oneonlywgs's Avatar
Sounds like boost cut.
josh3305
Mar 31, 2012 11:44 AM
Yakshii
Sep 14, 2010 09:04 AM
evo1981
Jul 14, 2010 05:23 AM
Rp.cudd
Apr 27, 2010 07:08 PM
4WS Tuning
29
Mar 14, 2007 01:09 AM
