Help with Swift Spec R spring install
I am working on installing a set of Swift Spec R springs on an Evo IX. I am having a problem with getting the top hat to seat properly on the top of the spring. Here are a few pics:
The separation starts to occur when I am torquing down the bolt on top of the top hat. What am I doing wrong? Is this separation normal and the spring properly seats under load (i.e., when I let the car down)?
Thanks in advance for any help you can offer.
You have to align the top spring perch first. Once it is seated right, then your tighten down the top hat. The spring should sit in the perch perfectly. Do not drive or install until then.
If you can't get it to do it right. Take them to a local shop and have them help you out.
Hope that helps
Hope that helps
Hope that helps
Hope that helps
The middle hole in the perch hat should be aligned with the hole on the strut assembly.
Pics and install instructions:
http://evomoto.com/tech_info.php?tPa...5684a61444e613
FS[MidWest]: Evo 9 Motor Partout
ihockey1
26
Oct 16, 2016 11:03 AM
03silverevo
Apr 14, 2012 01:35 PM
mac_05evo
Feb 27, 2007 06:08 AM
