Hooking up a spal slim fan?
How do you hook up a spal slim fan? I have one for my build and i was provided a plug that does not work with anything... Also recieved mounting tabs with it, i have no clue how they brace to the radiator. I would appreciate the help thanks..
The tabs that connect to the spal fan will go to where your factory fan bolted in place. The mounting tabs will go out at about a 45 degree angel to where your factory fan bolted in place.
For the connector you will have to splice in your factory connector to the fan.
You will also need to relocate your fan controller. I relocated it to the frame rail. Below the factory boost controller area.
supersnow
May 25, 2016 02:53 PM
