Overheating Issue
Old Aug 1, 2009 | 01:04 PM
MR. EVO MR's Avatar
Overheating Issue
i have a fp-red + bolt ons, I recently replaced my thermostat because it was leaking around the seam. she started overheating this morning 240 degrees I wasn't pushing her just driving 60-80mph in 6th, when I checked the coolant I noticed a silver/gold color liquid floating on top of the coolant, it was also underneath the radiator cap and over the new thermostat(this drive was actually her first drive with the new thermostat)
i put everything back including the gasket except thermostat.
Drove her home gently and still overheating (now without thermostat)
can someone tell me what happened and what I should do.
Thanks
Old Aug 2, 2009 | 12:34 AM
tscompusa2's Avatar
probably have air bubbles in the system. flush and redo it.
Old Aug 2, 2009 | 04:31 AM
MR. EVO MR's Avatar
What about the silver/gold stuff floating on top that covered everything?
Old Aug 2, 2009 | 04:46 AM
Smike's Avatar
Could be oil - if so, headgasket. Or was it more metallic - metal shaving like? Then I would do an oil analysis. A failing water pump would also cause overheating.
Old Aug 3, 2009 | 03:51 AM
MR. EVO MR's Avatar
the lets call it Gold color also sticky liquid not shavings.
could it be the material from the new thermostat that was installed?
bump for someone knowing what it is.
Old Aug 4, 2009 | 05:37 PM
MR. EVO MR's Avatar
bump
someone here must know what this is
Old Aug 4, 2009 | 07:23 PM
1sxyrxy's Avatar
If you let it idle how long will it take to overheat?
Old Aug 5, 2009 | 03:27 AM
MR. EVO MR's Avatar
after extensive research I came to the conclusion that the wax leaked out, this is whats covering everything.
I'd like to thank "How It's Made"
Old Aug 5, 2009 | 03:28 AM
MR. EVO MR's Avatar
I'll let you know this weekend
Old Aug 5, 2009 | 07:52 AM
tscompusa2's Avatar
The fiav on the throttle body also uses a wax pellet to determine warmup stage on the evo's same as dsm's. I didnt know the thermostats used wax as well.
Old Aug 5, 2009 | 03:18 PM
MR. EVO MR's Avatar
yes they do, check out youtube.com and search for How its made thermostats
cool to see
05LSMx
Lancer Troubleshooting
Apr 13, 2024 02:08 PM
bluebyu34
Nov 6, 2013 01:48 PM
<mojo>
12
Nov 12, 2012 02:07 PM
lil' jeff
Lancer Engine Tech
22
Jan 7, 2011 07:38 AM
cdupont03
Sep 19, 2006 09:15 PM
