Cruise control installation on an Evo 8/9
Hi,
If you've installed cruise on your Evo 8 or 9, can you please PM me? I have a few questions about the Rostra kit and The Lancer Shop couldn't really help me.
Thanks in advance!
-Franc
Evo8
Thanks in advance!
-Franc
Evo8
I might avoid that way.
I called these guys and they knew what I needed.
phone # is on website
http://www.mnrelectronics.com/roscruiscon.html
appears to be same company
http://www.thecruisecontrolstore.com/
there is an adapter you need to order to connect to the throttle cable
If you connect the rpm signal you can skip the clutch switch
I had problem where I needed more cable sticking out of the sheath due to my install location, so I believe I may have cut the sheath with dikes, be careful not to nick the cable
set the gain low, enjoy
FS[SouthEast]: OEM brake air guides new in box
franc01
Oct 21, 2015 09:48 PM
FS[SouthEast]: Evo 8/9 Mishimoto low-temp thermostat brand new in box
franc01
Jul 15, 2015 07:39 PM
