Best way to install/remove bushings
Old Oct 28, 2009 | 09:38 PM
charon2123's Avatar
I'm looking at installing the Perrin PSRS as well as some other suspension bushings this winter and was wondering if I 'have' to have a shop press or can I do it another way with a ball joint kit, or...
If I can avoid taking the stuff to a machine shop, that would be great (I will if I have to though).
Old Oct 29, 2009 | 08:16 AM
gsrboi80's Avatar
Press them out then in
Old Oct 29, 2009 | 09:58 AM
Solo II Evo's Avatar
Harbor freight tools sells a press for $100 or so. Definitely worthwhile!
Old Oct 29, 2009 | 10:14 AM
vicksen's Avatar
For those you will want to use a shop press with a proper sized die. A harbor freight kit will push the old rubber bushing out, but leave the metal ring in the control arm. You want it all out. If you went with the offset psrs make sure you line up your marks with a straight edge and use a sharpie to put reference marks to line up with when you press the new bushings in. Hope this helps.
Old Oct 29, 2009 | 10:49 AM
charon2123's Avatar
So a press it is, I was hoping to get away with not needing one. How would I get the metal ring out? Pliers and a lot of swearing? Also, I'm unfamiliar with presses, do I need a workbench or will it work on my garage floor?
Vicksen, thank you for the suggestion of the sharpie and straight edge!
Old Oct 29, 2009 | 11:08 AM
gsrboi80's Avatar
No you'll want an anchored press bench to press those suckers out
Old Oct 29, 2009 | 11:24 AM
Chemwarrior's Avatar
You could try cutting the old metal ring and then using a pair of pliers to pull the pieces out. Remember lube is your friend.
Old Nov 2, 2009 | 08:00 PM
Fourced4cyl's Avatar
Its not worth cutting it. Just get it pressed out at a good machine shop. Definitely worth it
BoostNY
Dec 17, 2016 02:31 PM
fireroasted
12
Mar 10, 2014 11:33 AM
TommiM
Jul 18, 2013 05:10 AM
chad99evo
Oct 12, 2011 11:02 PM
black evil evo
10
Jan 4, 2011 04:39 PM
