HOW TO: Timing Belt, Balancer Shaft Belt, and Accessory Belt Replacement
vibration after timing belt install
Looks like I made the wrong move by having a local mechanic put the new timing belt on. (should this be done at 60k on an '03 Evo?) As soon as I got in afterward, I could tell there was something wrong. The vibration is pretty subtle, almost unnoticable below 3,ooo rpm, and not so bad up from there. But when I put the clutch in to upshift there is a pretty bad vibratrion that is worse the higher the rpm above 3,000. Customer service guy at rock auto tells me the balance shaft is not right.
Is this where the turning the crankshaft 3 full turns comes in? Any advice on what I can tell him to help him get it right?
Same thing happenned with my '93 laser RS, except the vibration was really bad when it hit 3,000 during acceleration, even without hitting the clutch. Same issue? (That was a different machanic; took it back 3 times, no help, switched shops after that.)
I am dead smack in the middle of the install. Have yet to get the oem belts off yet, I seems as though I have to pull the power steering pump/bracket. For whatever reason mitsubishi decided that putting the bracket 1/2 way over the i guess they are idlers (theres one on the left and the right timing belt guide i guess. I dont think i can get a tool in there also. ? fact? its an evo ix.
BOTTOM OF STEP 6
"Remove Generator Brace, Qty3 12mm. Note: insert the really long screw back into place once the brace is removed. This will keep coolant from seeping out." ?????????????????????
what is this? the alternator brace?
BOTTOM OF STEP 6
Excellent write up with good pictures to go along with it
. Should be of great help to anyone with questions about doing this job.
Murph
Murph
Try having a friend hold it with 2 hands while you get the bolt loose. Or put the belt back on, tension it, and that should hold it still
BOTTOM OF STEP 6
BOTTOM OF STEP 6
Were you able to get it removed?
10isace, Any tips to getting that power steering pump off? Ihaven't started it yet, i was able to get the lower tb cover off leaving it all bolted up, but I think ill need more room to get it back on.
thanks,
Jimmy
thanks,
Jimmy
Just did the t-belt, bal belt & drive belt on my IX yesterday. It was not that bad to do. I did not have to do that oil pump hole thing I just used a white out to mark the old t-belt & bal belt with the gears & then matched it with the new t-belt & bal belt & installed back using the white out marks. Watch out for that exh cam gear as it will move if you do not secure it. Only weird thing that happened is once I got everything back together the car would not start but cranks. I pulled the top cover off & lined up the cam gear with the marks & then disconneted the neg batt cable for 10 secs & then the car started. Not really sure what happened there but the car runs now.
