HOW TO: Timing Belt, Balancer Shaft Belt, and Accessory Belt Replacement
So Im currently doing my evo 9 with the mivec. I noticed that the cam sprung forward when i removed the belt. Upon reinstall, I had to push it back in to position. Is this what you experienced. I don't recall the manual mentioning this. It seems the manual that I have is references the evo 8 install and so does yours unless I'm reading this wrong.
Also, when working with the tensioner, have you experienced issues with pulling the pin out after you wait the 15 minutes. I set the tensioner pully to pull the intake cam back in to position, and I wasn't able to use a reversible torque wrench so I just set it where it looked and felt tight. After I waited the 15 minutes the pin would not enter the tensioner and according to the manual it is suppose to. Right now I feel like just leaving it as is cause i don't have time to not have it running, and can't seem to get a hold of anybody who has done this task before.
I wouldn't put it back without correct tension. You can destroy your motor if the belt slips. You should get the tools that lock the cam gears into place. Makes it much easier.
Yeah this is one of those things I would rather just get it right the first time. I bought the cam locker tool from MAP I think. It's awesome and 100% worth every cent you spend on it. Makes this job way easier.
So this being My 6th attempt on getting the tension set correctly, for the auto tensioner I put pressure on the timing belt pulley, enough to be able to remove and insert the pin, turn the motor over a couple times and reinsert it afternoon waiting a few minutes. However when I press down on the belt between the cam gears, the belt seems to have way to much slack, and I'm worried that if I put everything back together and drive with it it may jump time. Will the auto tensioner tighten up after the motor is started? I adjusted the tensioner pulley further than recommended to get more slack out of the belt, but I cannot put the pin back in and the auto tensioner shaft is pressed in fairly far into the body. I have to use a vise to squeeze the tensioner in, so I don't think it's faulty. My main question is, am I just setting the assembled tension on the belt, and then will adjust itself when the motor is running?
I HATE to bring this up from the dead, but can anyone confirm this? Is it 100% needed to remove the crank bolt (22mm) to get the crank gear off so you can actually put in a new balance shaft belt? Is there enough room to finagle the balance shaft belt in behind the crank gear without removing it?
You need to be extremely careful not to bend the sensing blade and only move the crank slightly.
I can confirm that you can replace the balance shaft belt without removing the crank gear and sensing blade. There are two protrusions on the front case that get close to the sensing blade and prevent you from removing the belt at TDC. You need to rotate the crankshaft clockwise and counter-clockwise slightly so the raised sections of the sensing blade clear these protrusions allowing you to remove the belt and reinstall.
I LITERALLY just came in to check the torque specs for various timing belt parts and was going to respond that yes indeed, it definitely does work not having to take that crank gear/sensing blade off. You're 100% right with everything as described!
Lightsaber
Jun 7, 2017 03:58 PM
fireroasted
20
Mar 27, 2017 08:17 AM
