HOW TO: AEM UEGO serial cable
Old Feb 23, 2009, 05:42 PM
Drill_Sergeant's Avatar
Smile HOW TO: AEM UEGO serial cable
assuming you have already installed the gauge itself, this is for anyone who wants to know how to make the serial cable for logging.
this was just my method. opinions may vary...
as you can see the instructions as per AEM is pretty straight forward. blue wire to no. 2 pin and black/ground to no. 5 pin.
i purchased a db9/rs232 female connector from radio shack for $2.19 and soldered the wires to the pins. the pins are labeled so you cant really go wrong.
next i crimped and soldered connectors to the ends of the serial cable in this configuration. i'll explain why later.
your serial cable should look a little something like this...length may differ
in the car...
ignition power and ground for the gauge itself comes from my radio harness adaptor.
if you've noticed, the ground is bolted to body. the ground for the serial cable will also use this ground.
here, ive connected everything together. the gauge gets its power from the ignition source and is grounded through the body. connect the blue wire for the serial cable and the ground wire, which at the same time is grounded through the body.
and in this picture, ive disconnected the serial cable completely. but because of the configuration of the serial cable, i am able to still maintain a clean connection with the gauge.
thanks and enjoy.
Old Dec 7, 2009, 08:06 AM
20bell08's Avatar
Good Info! Sticky!
Old Jan 5, 2010, 08:25 PM
Sticky!
Old Apr 2, 2010, 03:57 PM
Kevin Knight's Avatar
weres the white go?
Old Apr 5, 2010, 08:40 PM
ValdezeEvo's Avatar
Originally Posted by Kevin Knight
weres the white go?
To another 0-5v I believe.
and awesome how-to, I used this to make mine.
Old Apr 7, 2010, 08:48 AM
the white is an analog 5v output. can be used with AEM EMS or can go into the 75pin slot on the stock 8 ECU for wideband logging without a serial cable.
basically, if you're using a serial cable to log AFRs on Evoscan, you can just leave it alone.
Old Oct 10, 2011, 04:48 PM
EvoIIIAj's Avatar
Awesome write up!
Old Oct 22, 2011, 02:18 PM
EvoIIIAj's Avatar
This worked like a charm for me!
Old Nov 15, 2012, 04:41 AM
211Ratsbud's Avatar
Anyone with win 7 using this ? Trying to nail down a serial to USB converter.
Old Nov 16, 2012, 05:52 PM
211Ratsbud's Avatar
picked up a gigaware and the appropriate connector for my AEM. So sick of fussing with random ground offsets in the stock ecu splicing method. WOT is 1-2 off every time and the idle is never even close.
using 0.03913*x+(anywhere from 7 to 10)
Drill_Sergeant
For Sale - Wheels / Tires
19
Sep 1, 2014 10:06 AM
SeanC
Aug 13, 2014 08:13 AM
Drill_Sergeant
For Sale - Cars For Sale
13
Jul 15, 2014 10:45 AM
Drill_Sergeant
May 26, 2014 12:59 PM
Quick Reply: HOW TO: AEM UEGO serial cable
