SRS light
Old Apr 17, 2010 | 09:42 PM
Jimevo9PI's Avatar
I called a mitsu local dealership here in Atlanta and they told me once the airbag has been removed there's no way you can get rid off the SRS light. But i'm still optimistic that somebody out there know how to disable the SRS light.
Originally Posted by lemmysports2
exactly what he said.. get a resistor installed then take your car to the dealer and get the srs fault code erased.. you should be fine after that.
Old Apr 17, 2010 | 09:55 PM
buchnerj's Avatar
You can buy a scanner at your local auto parts store (they are expensive), if no one in the area that you are friends with has one. You have to reset the code, unplug the battery, then install a resistor. Once the resistor is in place you plug the battery in and then it thinks the resistor is coming from the airbag module in the steering wheel, so it will not throw the code. You can not just unplug the battery and have the code go away though, I am pretty sure. You have to clear the code first, then install your resistor pack.
Old Apr 18, 2010 | 07:36 AM
Jimevo9PI's Avatar
Thanks but it is not clear to me how you reset/clear the code.
Old Apr 19, 2010 | 05:45 PM
Jimevo9PI's Avatar
Bump!
Old Apr 26, 2010 | 01:08 PM
Jimevo9PI's Avatar
Bump for more help!
Old Apr 26, 2010 | 01:21 PM
rcheung's Avatar
The SRS scanner is much like an OBD2 scanner where it plugs into the diagnostic port and resets the SRS code. If you have an aftermarket steering wheel and no resistor, don't bother trying to reset it because it wont work. If you find the resistor , get it installed and then find a shop that will try it. The dealership would probably not do it since you have an aftermarket steering wheel installed.
Something like this might work.
https://www.evolutionm.net/forums/ev...hub-locks.html
Old Apr 26, 2010 | 01:41 PM
awdboosted's Avatar
Pull the Air bag computer out. The light should go away.
Old Apr 26, 2010 | 06:08 PM
Jimevo9PI's Avatar
I got a works bell hub but doesnt come with a resistor.
Old Apr 26, 2010 | 06:13 PM
evoix10's Avatar
get rid of the light bulb?
Old Apr 26, 2010 | 06:23 PM
itscypha's Avatar
like said above remove the air bag chassis brain box. or just remove the bulb. if you dont need a airbag oh well for the passenger side. :-\
Old Apr 28, 2010 | 04:39 PM
Jimevo9PI's Avatar
So the resistor thing doesn't work at all?
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
KITT2012
Lancer Troubleshooting
May 1, 2017 12:22 PM
pqek666
Jun 29, 2015 11:58 PM
fyreant
May 30, 2014 06:34 PM
Silver06evo9mr
Dec 19, 2012 10:00 PM
