Gigantic Debadging/Badge Removal Thread
Old Jan 2, 2004 | 08:24 PM
odie3283's Avatar
Use fishing line to separate the glue from the emblem, then get some sticker remover and spray it on the glue...Wait a few minutes and wipe off
Old Jan 3, 2004 | 10:51 AM
joedown's Avatar
Thanks for the info.I need to remove the ES and some horrible MotorCars dealer badge.
Old Jan 6, 2004 | 09:08 PM
boomn29's Avatar
Had anyone done anything with the front diamond yet?? Like tried to fill it in or anything?
Old Jan 7, 2004 | 02:39 AM
neonsalamander's Avatar
Yes, I believe if you check out the "Tarmac Black" section in the Evo show & shine forums on the 3rd, 4th, or 5th page there was a guy who painted the front mitsu emblem blue.
Old Jan 8, 2004 | 10:04 AM
cdyancey's Avatar
i went and got some tamya model paint Translucent red. so it still has the under chrome appearance. it lloks sweet. I also used it on the clear light bar behind the Air Cond CTRLs so it lights up red as well............looks sweet!
Old Jan 8, 2004 | 06:32 PM
Axis of Evo's Avatar
Do you have any pics of your red tinted emblem?
Old Jan 8, 2004 | 06:34 PM
The best way to remove a glued-on badge is to use dental floss to "saw" it off. Then a little goof off to clean up the rest of the adhesive and you're all set.
Old Jan 8, 2004 | 06:39 PM
sleet's Avatar
depends how much adhesive **** you've got left over.
Old Jan 20, 2004 | 10:25 AM
petersa9's Avatar
NO GOOF OFF!!!! Just GOO GONE
There is a huge difference between goof off and goo gone. I used goof off for removing all the paint off a model car. Goo gone wouldn't even effect the paint unless you let it sit for a while.
THERE IS A REASON GOO OFF COMES IN A SMALL METAL CONTAINER AND GOO GONE COMES IN A PLASTIC CLEAR CONTAINER!!
Please advise I don't want to see you guys removing the clear coat or even top coat!
Andrew
kidneythief13
Jul 25, 2008 11:12 AM
str8rida
Jun 8, 2005 11:28 AM
littleengine
Mar 27, 2004 11:54 PM
STC
May 29, 2003 10:34 PM
