blitz sbc help... pls!!
Old Nov 28, 2003 | 02:26 PM
siQness's Avatar
i just got my car back after having it all ****ed up, if u guys remember, but the engine light is gone, i can drive the car fine now but there is one problem its only boosting at 11 psi. is it supposed to be like that, how do i change the boost controller to 19 psi to redline. pls help me. i would think it would still be stock boost.
Old Nov 28, 2003 | 07:36 PM
GTVEVO's Avatar
It is probably only boosting 11psi because it EBC is off or not set correctly. The blitz will control boost in PSI or Duty percent. You have several channels to set this up but you will need to select a channel and set the reading to PSI. Then after you do that dial in your desired boost level with the auto function selected. After this is done exit out to the boost guage or graph and you will see a big "L" on the top of the display then go out and to a couple of hard runs through the gears and it will dial in your desired levels automaticall and once the "L" disapears it is set. It is best for you to read the instruction manual so I attached the boost setting page below.
Old Nov 28, 2003 | 09:59 PM
siQness's Avatar
i keep adjusting boost and it still sats peak 0.01 still only going to 11
Old Nov 28, 2003 | 10:03 PM
GTVEVO's Avatar
If the guage doesn't work then it isn't measuring boost and you have a vacume problem that still needs to be fixed. If the guage goes to 11psi or above and you just can't get any higher setting then readjust your settings. If you aren't on auto then you will need to turn it up to about 58 for 19.5psi. If you are on auto you should be able to set it to the desired PSI that you want to be set at. Gain should be set at 32 and boost at 58 or 19.5 depending on your settings.
Old Feb 14, 2004 | 01:37 PM
STiTHIS's Avatar
should the stock seluniod be hooked up..?
Old Feb 14, 2004 | 09:28 PM
GTVEVO's Avatar
No the stock sylinoid should not be hooked up with vacume lines but it should be plugged in still electrically. Just cap it off using 2 caps your new EBC will control the boost completely.
EvoIXMR671
Dec 28, 2016 11:29 AM
Mikeodeth
Aug 10, 2015 05:13 PM
darwin_evo
Oct 11, 2011 08:10 AM
Gracer26
14
Sep 25, 2009 03:24 PM
flo2877
Nov 9, 2005 08:26 AM
