Help pls. Huge problem.
Old Sep 24, 2009 | 06:16 PM
Gracer26's Avatar
I dont know if the mechanic that is working on my car is a complete idiot or whatnot... I bought a brand new ACT clutch for my 05 Evo MR. The part numbers all match up on every site but the mechanic says that it doesnt fit. Help pls. i need to tell this guy something soon. i have never had this problem before.
Old Sep 24, 2009 | 06:43 PM
D-VO's Avatar
Whats the part number, so we could know which act clutch your talking about? Have you spoken with act?
Old Sep 24, 2009 | 06:49 PM
Gracer26's Avatar
mb7-xtss. working on talking to ACT. problem is it is after business hours. The car has a twin disc exedy and the mechanic is saying that the pressure plate wont fit in there. im thinking that the mechanic is an idiot and he is taking something else apart. i dont know.
Old Sep 24, 2009 | 07:01 PM
eponti's Avatar
That's the same part number I have on mine. Might wanna take it somewhere else.
Old Sep 24, 2009 | 07:27 PM
JohnDoe1984's Avatar
My guess is that he doesn't realize that when you bolt down the PP you have to work against the spring pressure to get the bolts in. It can be difficult to get them started. I know this because when I put mine on I thought at first that the pins that help line up the bolt holes were off and it wouldn't bolt down. Turned out I just had to get a few threads on the first bolt, tap it with a rubber mallet, and push hard on the other side to get the bolts started. Once they are started just tighten them one at a time to walk the PP all the way in.
I bet that is the issue. The xtss has an extra stiff spring on the pressure plate too so it's probably pretty hard to push against when installing. He might need to put some clamps on it to get it bolted.
All this said he is a mechanic and should know this stuff so I would debate taking it somewhere else. Considering he is at the point of putting the thing back together maybe you should just let him finish. You're more that half done.
Old Sep 24, 2009 | 07:57 PM
D-VO's Avatar
I agree, he's got the tranny off doesn't he? Tell him to just try it.
BTW: The last time I put in my clutch the disc wasn't aligned properly and I swore up and down it was. Maybe he made the same mistake.
*EDIT*
+2 on this one!
Originally Posted by Evil_1
If I'm understanding your statement quoted. I hope you're not trying to bolt the ACT to the Exedy Twin flywheel because that will not work. You need the OEM style fly wheel. Did you get a new flywheel with the ACT? If not, that is your problem.
Old Sep 24, 2009 | 08:05 PM
Evoryder's Avatar
Sounds like you went to the wrong place.
Alignment tool is a must. It is really not hard to do a clutch job with the right tools. Print out the evomoto.com how install a clutch, that's what I used and it worked perfect(they even use an ACT clutch)
http://evomoto.com/tech_articles.php?tech_article_id=27
Old Sep 24, 2009 | 09:28 PM
Evil_1's Avatar
Old Sep 24, 2009 | 09:48 PM
Peteypab2133's Avatar
ehhh, if he honestly doesnt know what he is doing, why do you wanna risk the chance of him totally fubaring it up? If he rocks like regular ATF, and over tightens them or under tightens them you will be in a world of pain. Talk to him, see what he doesnt understand. Allow a rep to talk him through it from ACT at the bare minimum.
If he doesnt feel comfortable forcing it in his opinion dont let him!
Old Sep 24, 2009 | 10:01 PM
EVILBLOODBROTHA's Avatar
Take it somewere else like a dealer. They should know how to do it.
Old Sep 24, 2009 | 10:03 PM
AF-Evo8's Avatar
^^^^^ i would have to agree with this, it the first thing that came into my mind.
Old Sep 24, 2009 | 10:57 PM
+1 this is probably the problem.
Old Sep 25, 2009 | 12:47 AM
Teal2nnr's Avatar
Take your car somewere else, or you'll be paying for his mistakes down the road. An make sure you call him an idiot before you take your car out of there.
Old Sep 25, 2009 | 11:42 AM
Gracer26's Avatar
Thanks for all the help. Im hoping to get to the bottom of this problem. I think that the problem will end up being the flywheel. I sent a ACT flywheel down to him but i bet he is trying to bolt it up to the one that is on the car. As soon as i figure out what this guy is doing wrong ill let him know what he should be doing.
Old Sep 25, 2009 | 03:24 PM
SpoolinUp's Avatar
Silver Sponsor
The mecanic really should know better though....
Part number on the flywheel?
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
EvoIXMR671
Dec 28, 2016 11:29 AM
KOTT
Aug 27, 2016 11:51 PM
ledokol
Oct 26, 2010 01:16 AM
ashar
Mar 23, 2010 08:32 PM
ctdragon
Mar 7, 2005 08:40 AM
