clutch install question, differential wont come out.
Old Dec 2, 2003 | 06:29 PM
svue's Avatar
Hello,
For those of you out there. I am having a hard time sliding out the differential, it slides out about 2 inches and seems to be stuck. Do I just have to pry it out real hard, or is there anything else holding it. Everything seems loose already, and it looks like there might a clip or a ring or something.
That is the last step before, I can slid out the transmission.
any suggection will help.
thanks
Old Dec 2, 2003 | 06:36 PM
sr20det91's Avatar
I believe there is an inner sleeve of some sort that needs a slide hammer to remove. Someone did a write up on a clutch replacement and said he didn't use one, but this seems like its the exception not the rule.
Do a search and you should be able to find it. It was a pretty good read. There were pics. and what not. It may help you out.
Old Dec 3, 2003 | 10:20 AM
QuantumEVO's Avatar
There are two shafts that must be removed with a slide hammer. They are caught in there by a retaining clip.
Mark
www.Quantum-Racing.com
Old Dec 3, 2003 | 10:43 AM
AC-EVO's Avatar
hi guys
is it hard to install the clutch?? cuz if its too hard then i juss gonna install it at the bodyshop...
thanx...
Old Dec 4, 2003 | 03:54 PM
IgotaWhiteOne's Avatar
yea its pretty tuff it took us about 6 hours total that is cause we took breaks i got the exedy twin plate love it i also installed the stainless steel clutch line which was awesome too now when i launch with my bald tires i get all four smoking. The only hard part was bench pressing the transmission back up
Old Dec 4, 2003 | 10:27 PM
superz's Avatar
You need to remove the shaft that sticks out of the drivers side axle hole in the tranny. It requires a slide hammer. You only need to remove the driver's side shaft.
jeg5263
Lancer Tranny/Drivetrain Tech
Mar 6, 2016 07:50 PM
pukka
Jul 2, 2013 09:48 AM
deylag
10
Sep 4, 2011 12:27 AM
boomn29
28
Oct 3, 2007 08:43 AM
NWEvoViii
17
May 21, 2007 04:40 AM
