IAT sensor wiring???
hello can someone explain or show with pics how to wire a aem iat sensor pls cant find anything very helpful after searching so i posted a thread
From: Detroit metro area Michigan/Washington DC metro area
BUMP
Looking for speed density/IAT answers aswell? i have a OMNI 4 bar sensor and IAT, i picked up the SD sensor bundle from ECM LINK trying to get more info and details as to how people install this. Ex: hardwired, patch harness, both?
depends on which rom your using some use the fuel temp sensor pin some use the maf air temp wires . map sensor also depends on rom and whether or not your car already had the sensor in the manifold as manifold differential pressure sensor.
info
https://www.evolutionm.net/forums/ev...+sensor+wiring
https://www.evolutionm.net/forums/ec...ched-roms.html
info
