clutch help please!!
Old Nov 9, 2011 | 02:54 PM
evoscott's Avatar
Ok so I have everything apart but can not for the life of me get the throw out bearing to release so the trans will come off!! I dnt know if I'm doing it wrong but I'm prying the tob away from the pressure plate while the clutch fork is all the way twords driver side like the picture says but will not let loose.. any good tips? Thanks to all
Old Nov 9, 2011 | 05:04 PM
cfdfireman1's Avatar
http://www.driventomodify.com/showth...earing-release
the bottom part stays with the pressure plate, top part stays in the fork
Old Nov 11, 2011 | 04:36 AM
r_ace_r's Avatar
if it won't come off you can try to rotate a crankshaft 90 degree at a time and repeat the above mentioned procedure
Old Nov 11, 2011 | 04:39 AM
Jersey Dino's Avatar
when you are manipulating the clutch fork make sure you are rotating the screw driver as if you are tightening or loosening a screw. its not a prying motion
MikeB@FFTEC
36
Nov 4, 2019 05:23 PM
dxn036
Sep 5, 2017 08:09 PM
verticalspark
Lancer Tranny/Drivetrain Tech
Oct 19, 2015 06:03 PM
Craig King
11
May 19, 2011 07:11 PM
plokivos
63
Mar 17, 2005 09:14 AM
