Help: How to fully remove back seat?
Old Jan 23, 2004 | 09:04 AM
spicytuna's Avatar
I haven't tried yet, and I don't assume its difficult... but I thought I'd check first.
I know step one would be to remove the lower cushion. I know that you can remove the bottom of the rear seat by using certain tabs on each side to release it from the catches.
After this step I don't know hoe to remove the back portion of the seat. Any tips??
Old Jan 23, 2004 | 11:44 AM
jotan82's Avatar
it's not worth it to remove the back seat... there's more hassle than what it's worth...
but like you said, there are two tabs on each side for the lower cushion
the top cushion, there are (3) 14mm bolts on the bottom, after unbolting, slide the cushion upwards and TADA
not 100% positive about the bolt size, but i believe it's 14mm
Old Jan 25, 2004 | 08:05 PM
Cajun Power's Avatar
yup
He's right, it is that easy. Don't be afraid of this one. They are easy to remove and you can't mess it up. After removing the lower bolts on the back of the set just lift the back verticly and it will pop out.
14MM sounds right
Old Sep 21, 2007 | 06:08 AM
Warrtalon's Avatar
12mm
barneyb
May 13, 2018 08:24 PM
Dragking2189
Oct 24, 2016 02:41 PM
drucea
Oct 20, 2005 12:35 AM
Shaker Motorsports
Jun 29, 2005 07:45 AM
SeanT
Jul 1, 2004 10:21 PM
