instalation notes on ss clutch line?
anyone have notes to give out on the ss clutch line stall? beside bleeding the lines, how long did it take? any major issues?
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally posted by JustDSM
http://www.evomoto.com/tech_info.php?techID=26
I find it unnecessary to remove the hard line. Leave it in place with the clip and break the fitting loose on the car--no need for a vice. After the connection is loose, then remove the clip and the rubber line. I would also bleed the fluid out of the line before you start removing anything. With the battery and airbox out, you shouldn't have to touch the upper I/C pipe.
David Buschur
EvoX 'For Sale' Suspension / Brakes / Handling
Feb 12, 2014 09:16 AM
evoixbri
Mar 15, 2009 08:20 PM
Xshieldsx
18
Dec 12, 2005 11:25 AM
