Trunk pop solenoid install pictures
I used a solenoid that looks the same. It is a pretty easy install. Yours looks better than mine though. I mounted my relay under the dash with the alarm. I also disconnected the factory trunk release in the car so you have to find the hidden button to open the trunk.
I originally attached the trunk solenoid to the emergency latch, but that way didn't work very well as the spring on that latch is softer. Another issue I had with using that latch was getting the trunk switch to engage when the trunk was closed. My alarm would think the trunk was still open even though it was closed.
So I later attached the solenoid to the trunk release cable latch, which seems to work better, but it still doesn't open the trunk 100% of the time. I've spent many hours trying to tweak this setup, but the best I can do is to get this thing to open about 80% of the time. I already tried repositioning and reorienting the solenoid, but it didn't seem to make much difference.
Nice use of the hard plastic sheeth/tubing I must say though, what exactly did you use?
Here's how my trunk pop solenoid relay is wired up:
85 - Constant 12V power
30 - To solenoid (the other solenoid terminal goes to ground)
86 - trigger wire from alarm (jumped with 87)
87 - trigger wire from alarm (jumped with 86)
87a - not used
87a - not used
Wiring detals:
I found that there were already 2 wires nearby there, so I chose the green wire with the silver dots to use as the + trigger and then I grounded the other terminal of the solenoid to the trunk lid itself. The green wire runs up to the driver's side kick panel I cut it there and spliced in my trunk pop release output from my alarm at that point. A relay may or may not be needed for your particular install. Good Luck!
Thugline
Aug 24, 2015 09:57 AM
m4tt VIII
For Sale - Cars For Sale
10
Jul 18, 2012 09:17 AM
smackdaddy
52
Mar 21, 2004 06:07 PM
