Evo V Shift boot/Center console removal
Old Aug 4, 2014 | 09:01 PM
loslogo's Avatar
I've done a bunch of searches but I cant find out how to remove the shift boot, does it click out or do i have to remove the console and unscrew from beneath?
are there any pictures anywhere of the process?
Old Aug 5, 2014 | 05:53 PM
loslogo's Avatar
anyone?
Old Sep 29, 2014 | 06:13 PM
thomasy154's Avatar
Removing shift boot
Hey mate, very easy just replaced mine on a evo 4, same setup.
you have to remove the surrounding of the handbrake.
there are 2 screws in bottom of the parcel tray were your elbow usually sits
1 screw behind the ashtray thats for the back seat
then remove it and you will see 2 screws infront of the handbrake that hold the surrounding of your gear boot
then remove the the front ashtray and cig lighter
then remove the plastic in the dash that covers your head unit etc
you will then find another couuple screws
then pull it out, and there are four screw holding your gear boot in
Old Sep 29, 2014 | 06:15 PM
ak47po's Avatar
http://www.evoscan.com/vehicle-manuals
Old Aug 11, 2018 | 11:54 PM
Eddie-EvoIV's Avatar
Hi all,
I know its a bit dated, but I thought I'd add to this thread in case anyone comes across it (like I just did).
I've got the hard copies of the manuals, downloaded from the link supplied by AK, but I couldn't find any mention of the shift boot - maybe I missed it.
So, I followed Thomasy's guide. As he/she says, it was quick and easy to do. The only thing I would like to add, is that once you have removed the front ashtray and cigarette lighter - the surround that hold the head unit in place just pops out. There are 4 push fittings, two on the top left and right, and two on the bottom (left and right). Just gently apply even pressure (pulling) to both sides and it will just pop out.
yellowevo82
Jul 13, 2016 01:02 PM
Ecr33
Nov 29, 2015 03:29 PM
ch1215g
Feb 13, 2011 03:08 PM
JoNaH
11
Feb 13, 2011 12:12 PM
03evo8kevin
Sep 25, 2008 02:16 PM
