evo 9 mr with 5 speed what shiftboot??
Old Nov 17, 2015 | 08:59 AM
Ecr33's Avatar
So i have an evo 9 mr console with a 5 speed transmission, does the oem 5 speed shift boot fit the mr console? Other then having a shift boot custom made, how can this problem be fixed
Old Nov 18, 2015 | 11:19 AM
krazybai's Avatar
bump....wondering the same thing.
Old Nov 18, 2015 | 11:33 AM
evo.matt's Avatar
I'm in search of an MR shifter console and am offering my 5spd one up for trade. I've already did some research and it does work with some light modification on my end. As for the GSR shifter console in the MR, if you have the 5spd conversion it will work.
Old Nov 18, 2015 | 12:24 PM
Ecr33's Avatar
well the question still remains for people with the mr console and a 5 speed trans
what do you do if you want a proper fitting shift boot? because the 6 speed shift boot leaves a large gap because theirs no reverse lock out.
Old Nov 18, 2015 | 01:10 PM
Turndown's Avatar
Veteran: Army
I've just learned to live with the gap lol
Old Nov 19, 2015 | 06:27 AM
egis's Avatar
STM sells 5 speed boot for $42 if you want that neat look.
Old Nov 19, 2015 | 09:34 AM
Ecr33's Avatar
if anyone can conform this works please post but im sure the 5 speed boot is smaller then the 6 speed console opening
Old Nov 19, 2015 | 10:18 AM
egis's Avatar
When you say console opening you mean that ring right?
Old Nov 20, 2015 | 10:02 AM
luvboost's Avatar
what I'd do is match a DIY for removing both and see of the screws are in the same place and everything is similar. From what I'm seeing though it looks like the MR boot is wrapped in a wider diameter around the console.
May have to get a 5 speed console top.
Old Nov 21, 2015 | 09:47 PM
Teal2nnr's Avatar
I believe you need the 5 speed console. I just live with the gap, I prefer the MR console.
Old Nov 29, 2015 | 03:29 PM
Rolston12's Avatar
i have the same set up on my MR I installed a Works Short Throw Shifter and it doesn't look haft bad
TheNEWB
Evo X How Tos / Installations
Mar 14, 2011 06:05 PM
paradoxx
Aug 29, 2006 06:36 AM
Varrius
Aug 11, 2006 04:40 PM
Varrius
Aug 10, 2006 05:42 AM
donmeca2020
Sep 8, 2005 08:07 AM
