Water temperature sensor?
Originally Posted by Ev0ikon
errr... can you just read the temp value from the ECU? Why the extra sensor/adaptor?
And by the way i also have a PSI3 unit and it takes and reads temp from the ECU but it always seems off next to my Defi.
Do you have OEM upper hose or Samco? I'm thinking you had the Samco hose that is what i have, and if your going to get them you'll need the 32mm.
I got it from evostore.com. It's not on their website, so I just called to place the order. I had to wait like 2-3 weeks for it to arrive. I ordered mine back in late October I think.
I have the Greddy adapter and there's a few things I want to add...
1. You will not get an accurate reading until the thermostat opens and the coolant flows through the upper radiator hose. If you want an accurate reading of the actual temp, tap into the thermostat housing.
2. Since the radiator hose is rubber, you will need to run a ground wire off the sensor.
I'll eventually get a tee for the stock and aftermarket sensors but I'll wait until it's time to flush the coolant since there's no reason for me to drain it again now other than to move the sensor.
[WTB] Stock oil temp sensor
Howulikemyevo
Mar 29, 2016 08:58 PM
bignasty_yagn
Lancer Aftermarket Forced Induction Tech
13
Feb 4, 2010 11:52 AM
sharkm87
13
Jun 26, 2007 01:35 PM
