Alpine headunit install, lined up?
Old Mar 22, 2004 | 06:55 AM
d1_evo's Avatar
guys i know this is a stupid question but when i tried to install my Alpine headunit i couldnt get it to line up flush with the dash and get the dash panel to back on due to the head units bezel..i see i might be stuck not using the bezel but it looks like sh*t like that... anyone have any pics of there headunit (Alpine) installed i can see?
thanks
S.
Old Mar 22, 2004 | 07:00 AM
trubidou's Avatar
I don't think any stereo will fit with the bezel. Mine didn't....although it's a kenwood, it should be same basic dimensions and mount points.
Old Mar 22, 2004 | 07:06 AM
PRVRT's Avatar
You are going to need a trim that comes with all Alpines that locks in place! All aftermarket heead units do not fit flush do to the stock head unit is very wide!
Old Mar 22, 2004 | 07:19 AM
PRVRT's Avatar
There is a pic on this page, notice the trim around the sound processor(top) and the head unit(bottom)! The pics are on page 3 http://www.sounddomain.com/id/evoguy ! Hope this helped! Good Luck!
Old Mar 22, 2004 | 07:22 AM
EvoVIIIGuy's Avatar
Page 3 on my website
Http://members.sounddomain.com/evoguy
Old Mar 22, 2004 | 07:30 AM
PRVRT's Avatar
I just beat you to the punch!!!!
Old Mar 22, 2004 | 07:38 AM
d1_evo's Avatar
thanks for the insight guys! but i do have that "trim" that your talking about and i see it being used on page 3.. I have a Alpine unit and it doesnt seem i can get the head unit forward enough to get the "trim" on... on top of that, the dash console seems to hit the outer (left/right side) metal "tabs" on my alpine unit.. should i just bend those tabs a little?
thanks for the instight again im sort of a stereo newbie
S.
Old Mar 22, 2004 | 07:44 AM
PRVRT's Avatar
Did you take out the trim around the head unit and the A/C? And those braces hace to go unto the security sleve of the head unit! (If I am correct) Pix would help!
Old Mar 22, 2004 | 07:50 AM
d1_evo's Avatar
yes i have the A/C dash console off and teh security sleeve off.. ill try to install it again today.. maybe i want thinking correctly last night
Old Mar 22, 2004 | 10:28 PM
d1_evo's Avatar
ok i see that you got the trim to fit on your alpine processor.. after putting the side mounting brackets on my Alpine unit i cant get the unit to sit forward enough (out of the dash console) to fit the trim to lock in... did you do any trimming or anything to the side mountiing brackets? am i missing someting here?
Old Mar 23, 2004 | 08:17 PM
mksevo's Avatar
i had mine installed and the tech guy did add some other screw holes to the case side to be able to put the screws and bracket where you want , he first put them further up and inset the unit but it didnt look good since the edges were visible. i put it back and just attached the outer cover with velcro to hide the seams around the unit. i dont think any unit will fit perfect .
Old Mar 24, 2004 | 03:03 PM
d1_evo's Avatar
guys i got it to work.. on my Alpine unit i had to bend a couple of little "mounts" that stick out on the side.. after bending them forward, the dash console fit right over it
Old Mar 24, 2004 | 03:47 PM
mksevo's Avatar
shoot us some pics
Old Mar 28, 2004 | 10:43 PM
kidwitevo's Avatar
i had to shave mine with the dremel to get my alpine to fit. I wish i would have pu t it in the change compartment to take advantage of the tilt feature. Also, its really annoying right there in the center of the silver pastic crap. stands out
m0nkie
May 29, 2017 09:55 PM
bhmax
Feb 11, 2016 04:44 AM
fugiwara
27
Jul 20, 2013 08:44 AM
jasonn
Jan 30, 2012 10:40 AM
ru4real
12
May 7, 2007 11:28 PM
