Cannot tighten nuts on o2 housing
Old Oct 4, 2017 | 03:21 AM
McRooster's Avatar
I got an invidia o2 housing and I can't put the 2 nuts back on the bottom as the housing is too big and will not allow me to fit them around. Will this cause any issues if I do not put them back on?
Old Oct 4, 2017 | 07:07 AM
4b11slayer's Avatar
Remove all bolts. And seperate housing from turbo and install nuts before bolts.
If i understood correctly. The nuts are hitting the housing? So if you seperate it and make the studs become short it will dive you that extra room.
Old Oct 4, 2017 | 07:11 AM
McRooster's Avatar
Correct. The nuts hit the housing.
Old Oct 4, 2017 | 08:25 AM
4b11slayer's Avatar
Like i said remove remainding bolts and back off housing and start nuts. Yes it will cause an exhaust leak. Eventually. In time the exhaust gas will eat away the gasket.
AMS
Automotosports - Illinois
29
Jun 14, 2005 09:23 PM
boostedwrx
Feb 11, 2005 05:52 PM
ozmaster
Aug 27, 2004 12:09 PM
OZThunderGray03
Feb 23, 2004 08:55 AM
cleofis
Jan 15, 2004 01:37 AM
