Request: Rear subframe and suspension remover
Old Mar 28, 2020 | 06:12 PM
silverflyer's Avatar
Request: Rear subframe and suspension removal
What is the best way to remove the rear subframe and suspension all in one piece?
I am trying to do some undercoating and want space to work.
Picture for attention:
Old Apr 1, 2020 | 09:34 PM
deylag's Avatar
There are a couple chassis points where you have to disconnect suspension arms. Its not like the front where it can be unbolted as the way you describe.
Old Apr 1, 2020 | 11:06 PM
I decided to start with removing the rear diff (via the sway bar end link method). That frees up some space (also weight) to access the rear subframe. Then I think I’m going to detach all the suspension arms where they mount to the car. Then drop the subframe.
Old Oct 21, 2023 | 02:53 PM
Icecruncher's Avatar
any more pictures? Do the axles just pop out? Doesn't look like there are any bolts holding that on :S
Ronnie Size
Nov 23, 2014 06:19 PM
EvoJoeRacing
Jan 11, 2012 08:52 AM
