98 Evo V Clutch Safety Switch Install
Old Jan 30, 2025 | 06:05 PM
98EvoV's Avatar
Hey guys. My car didn’t have a clutch safety switch when I bought it. Now I can’t pass VA state inspection without it. I can’t find a single resource on how to install one. Anyone have any advice? Thanks in advance.
Old Jan 31, 2025 | 08:08 AM
schuhie's Avatar
Well, step 1 would be to see if here is already a switch and/or wiring by the pedal already.
A lot of people have simply unplugged them to save wear on the thrust bearings in the motor from pushing the clutch without oil pressure.
If there is a switch and wiring, you should be good to go. Wiring, no switch should be ok as well. Find the original mount or make you own and add something like the evo 8/9 switch.
No wiring; switch or no, is kind of a mess. At that point I personally would probably wiring it into the ignition power if its absolutely needed. By far the hardest of the possible options.
Get under that dash and start poking around, only way to figure out whats going on.
BubbaWhoaTep
Lancer How Tos / Installations
Aug 31, 2020 08:49 PM
kindaloweredlif
Jul 26, 2015 08:34 PM
lytleflo
Jul 10, 2007 02:54 PM
Shonoff
Aug 10, 2006 07:32 PM
GusandoX
Jul 29, 2005 06:49 PM
