hks hi power
hks hi power
i just picked one up used.... did it originally come with bolts and hardware besides the gasket? or does it use existing bolts and gaskets? I have two bolts, two screws and two washers, and a gasket,... the pipes, and the two brackets.
thanks
BUDLoNG
thanks
BUDLoNG
Let me try to remember.
You should have the 2 nuts/bolts/washers and gasket for where the two halves bolt together.
You should also have 2 bolts for where the rear hanger bracket bolts to the frame (above the muffler).
The frame has pre-threaded holes.
The cat connection used existing HW - the factory cat is studs that go through the flange with nuts.
My UR cat come with the nuts/bolts (but no gaskets).
Hope that helps.
Hope that helps.
Check out this thread. It has great pics and everthing.
https://www.evolutionm.net/forums/sh...ad.php?t=41891
This is what I used.
i used that page for reference.. but it doesnt really show the bolts that hold on the brackets... im gonna have to buy some, so i need to know the size, thread count...etc
the resonator is 4 inches too long... it was sitting against the gas tank heat shield...
i bought the exhaust off another guy... and i think he screwed me...
maybe it was for an evo7 not an 8...
if anyone has an hks hipower exhaust for either the evo7 or evo8 can you please measure the length of the resonator? mine is 18" long... 4" to much..
BUDLoNG
BUDLoNG
FS[MidWest]: COBB Downpipe for Evo X
g7igo7
Jul 12, 2017 04:37 PM
scottatyamaha
Sep 21, 2007 05:16 AM
