Which hose to tap for boost gauge?
Old Jul 28, 2004 | 03:16 PM
inariv5573's Avatar
There are two places I have seen where to tap for boost gauge. A guy on this site tapped into the hose going from the FPR solenoid to the intake manifold. But then Evomoto.com, in their tech section tapped into the hose connecting the FPR solenoid to the fuel pressure regulator. They said this reads pressure 24/7 so it's a prime candidate. Does it matter which hose? They both originate from the FPR solenoid, one from the top the other the bottom, but go in opposite directions to different areas.
Old Jul 28, 2004 | 03:23 PM
WRC4ever's Avatar
I tap from the hose directly from the turbo to the boost pressure solenoid.
Different ways of accomplishing the same thing.
Old Jul 28, 2004 | 03:25 PM
MYEVOVIII's Avatar
Tap into the line before the fuel pressure solonoid this way it will not have any fluctuations by the solonoid itself.
Old Jul 28, 2004 | 03:28 PM
Quickshift's Avatar
Or you can just tap the line that is going to your BOV as well. It is a little safer incase if one of your connections became lose at the regulator you could get a lean condition which isnt to safe.
Old Jul 28, 2004 | 03:37 PM
MYEVOVIII's Avatar
True I did not think of that. I wonder if the the stock sensor reads of the the line coming from the turbo or a different location.
Old Jul 28, 2004 | 03:42 PM
Quickshift's Avatar
That line is coming directly off the intake manifold so it should have accurate reading. Just like any other spot coming of the manifold.
Old Jul 28, 2004 | 03:46 PM
PoorBoys's Avatar
There is a great write-up with pics here: https://www.evolutionm.net/forums/sh...ad.php?t=80775
Old Jul 28, 2004 | 03:47 PM
TearItUpSports's Avatar
This is where I would do it. The BOV is less sensitive to the pressure drop from adding the T as well.
If you are going to tap the FPR line, do it between the manifold and solenoid.
Old Jul 28, 2004 | 04:19 PM
MYEVOVIII's Avatar
I installed mine between the manifold and the FPR sensor.
Old Jul 28, 2004 | 07:14 PM
LancerEvoMR's Avatar
Moving to Evo H/T Questions.
Old Jul 28, 2004 | 07:32 PM
SOUTHSIDEITALIA's Avatar
With a lil advice from AMS techs, I tapped the line directly off the manifold right after the throttle body. Same line the BOV runs through, but follow it to the manifold. Input from the line running along the engine plug cover. I believe this initally caused some problems, throwing a SES with a low flow condition from my EGR valve, but this was with a 3" catback, and always at low RPM's. Adding the Forge DV, Perrin downpipe and UR test pipe, no SES to date, car runs beautiful, holds 20+ psi all the way to redline.
Old Jul 28, 2004 | 08:05 PM
inariv5573's Avatar
Lines going to the throttle body are not as dead on, as stated by Evomoto.com. Tapping between the turbo and boost control solenoid probably won't read vacuum, not to mention it probably isn't accurate as well. Someone stated before the FPR solenoid. Which is before the solenoid, since there are 2 hoses coming out of it.
Old Jul 28, 2004 | 10:05 PM
Before the solenoid is the hose that runs from the manifold to the solenoid, NOT the one running from solenoid to the FPR. Like I said before I would tap it into the hose that goes from the manifold to the BOV. It is the one farthest right (not the ones on the throttle body).
Old Jul 31, 2004 | 12:59 PM
ivanko's Avatar
I went with the SPA Gauge for exceptional accuracy and quality.
I'm going to tap into the brake booster line via a brass t.
Adam Auerbach
Evo 7 RS RHD
GMC Syclone #2419
trinibt65
Apr 14, 2016 02:18 PM
LIL EVOL
11
May 5, 2009 04:47 PM
Mr. Stock
Nov 10, 2005 06:37 PM
schleppy
Jun 30, 2004 02:25 PM
