need help with power terminal to ignition switch
I am installing a amp to a factory deck into my lancer so there is no power auto-antenna relay control wire. That's what the directions say to connect to. It says if you don't have one of those to connect the male terminal to the power terminal through the ignition switch. What is the color of that and where is it located? I'm totally lost here please help!!
you can also hook this up to the ACC wire from your stock deck, use a volt meter to find the power wire and then the ACC wire should be right next to it, you can test this when you turn the key to the on position. Hope that helps.
